Posi Rear end
kenf729
PostPosted: Wed Apr 04, 2007 8:06 am    Post subject: Posi Rear end Reply with quote
I need a rear end, would like a posi, Just got my car on the road and the rear sounds like an old truck...lots of whinning...anyone have one for sale, it dosn't need to be disk...anyhelp would be appreciated.
Ken
kurfbird
PostPosted: Wed Apr 04, 2007 9:11 am    Post subject: Posi disk Reply with quote
I have a posi disk rear end form a 87 iroc Z asking 250.00 Does not include the sway bar. I live in Oak Harbor Wa Whidbey Island has 75,000 miles on it. I will have to open it up to make sure its good to go. LMk if interested
I also have a non posi 3.42 drum rear end for 50.00
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
kenf729
PostPosted: Wed Apr 04, 2007 9:23 am    Post subject: Reply with quote
I am interested...let me know what it looks like, Oak Harbor would be great get away for the day!!!
Also whats all involved in swapping out drum to disk? I thought I'd read it's a direct bolt on except for the E-brake cable? Any idea whats involved?
would you be willing to meet me in Everett, I'm making a trip there in about 3 weeks?
Ken
edit for spelling....
kurfbird
PostPosted: Wed Apr 04, 2007 9:39 am    Post subject: It should be a direct bolt on Reply with quote
It should be a direct bolt on. I would be willing to meet at exit 200 which is marysville exit. Comes with everything except the rear sway bar. Put that on my car
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kenf729
PostPosted: Wed Apr 04, 2007 10:01 am    Post subject: Reply with quote
Great, I take it my sway bar would work? also how about shocks direct bolt on? if you PM me your phone number I'll give you a call prior to me heading that way. My plan is to head that way on the weekend of the 21st.
Ken
PostPosted: Wed Apr 04, 2007 10:02 am    Post subject: Reply with quote
the shocks and sway bars will mount right up. all 3rd gen rears are the same that way.
kenf729
PostPosted: Wed Apr 04, 2007 10:29 am    Post subject: Reply with quote
Thank you, now what about the issues with the E-brake cable? will I have fab a mount or something? whats different from the two, length, routing?
kenf729
PostPosted: Wed Apr 04, 2007 10:41 am    Post subject: Re: Posi disk Reply with quote
One more last question is the posi a 2.73 or the 3.27 either way I'm totally interested.
kurfbird
PostPosted: Wed Apr 04, 2007 10:48 am    Post subject: Its a 3.23 Reply with quote
its a 3.23 rear end Everything looks the same. have part a non posi and the clamps for the ebrake and the routing look the same.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kenf729
PostPosted: Wed Apr 04, 2007 10:57 am    Post subject: Reply with quote
great, and I assume when you say everything comes with it, it includes the calipers and break lines? if so I give you a call around the 20th to keep you posted.
Ken
PostPosted: Wed Apr 04, 2007 11:08 am    Post subject: Reply with quote
as long as you have the same brakes the cables will be identical. if you are going from drum to disc or something the cables are available from napa/scmhucks/bastards/vato-zone for -+15.00
kenf729
PostPosted: Wed Apr 04, 2007 11:10 am    Post subject: Reply with quote
thanks going from Drum to disk, so I would need the cables then...I really appreciate this site lots of helpful information here...
Ken
kurfbird
PostPosted: Wed Apr 04, 2007 11:20 am    Post subject: The rear end comes with the cables Reply with quote
The rear end comes with the cables.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kurfbird
PostPosted: Wed Apr 04, 2007 11:21 am    Post subject: Everything Reply with quote
Yes calipers, brake lines, rotors, backing plate, brake cables, pads. etec etc etc
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kenf729
PostPosted: Wed Apr 04, 2007 11:44 am    Post subject: Reply with quote
sweet, consider it sold...
kurfbird
PostPosted: Wed Apr 04, 2007 12:36 pm    Post subject: Okay Reply with quote
Okay
Just Let me know if you change your mind. I am going to open it up this weekend and check the gears. etc. Will let you know the results
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
