kenf729 Member
Joined: 22 Mar 2007 Posts: 88 Location: Forest Grove, Oregon
Posted: Wed Apr 04, 2007 8:06 am Post subject: Posi Rear end |
I need a rear end, would like a posi, Just got my car on the road and the rear sounds like an old truck...lots of whinning...anyone have one for sale, it dosn't need to be disk...anyhelp would be appreciated.
Ken |
kurfbird Member
Posted: Wed Apr 04, 2007 9:11 am Post subject: Posi disk |
I have a posi disk rear end form a 87 iroc Z asking 250.00 Does not include the sway bar. I live in Oak Harbor Wa Whidbey Island has 75,000 miles on it. I will have to open it up to make sure its good to go. LMk if interested
I also have a non posi 3.42 drum rear end for 50.00 _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
kenf729 Member
Posted: Wed Apr 04, 2007 9:23 am Post subject: |
I am interested...let me know what it looks like, Oak Harbor would be great get away for the day!!!
Also whats all involved in swapping out drum to disk? I thought I'd read it's a direct bolt on except for the E-brake cable? Any idea whats involved?
would you be willing to meet me in Everett, I'm making a trip there in about 3 weeks?
Ken
edit for spelling.... |
kurfbird Member
Posted: Wed Apr 04, 2007 9:39 am Post subject: It should be a direct bolt on |
It should be a direct bolt on. I would be willing to meet at exit 200 which is marysville exit. Comes with everything except the rear sway bar. Put that on my car _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
brucesthirdgenparts.com |
kenf729 Member
Posted: Wed Apr 04, 2007 10:01 am Post subject: |
Great, I take it my sway bar would work? also how about shocks direct bolt on? if you PM me your phone number I'll give you a call prior to me heading that way. My plan is to head that way on the weekend of the 21st.
Ken |
Posted: Wed Apr 04, 2007 10:02 am Post subject: |
| the shocks and sway bars will mount right up. all 3rd gen rears are the same that way. |
kenf729 Member
Posted: Wed Apr 04, 2007 10:29 am Post subject: |
| Thank you, now what about the issues with the E-brake cable? will I have fab a mount or something? whats different from the two, length, routing? |
kenf729 Member
Posted: Wed Apr 04, 2007 10:41 am Post subject: Re: Posi disk |
| kurfbird wrote: | I have a posi disk rear end form a 87 iroc Z asking 250.00 Does not include the sway bar. I live in Oak Harbor Wa Whidbey Island has 75,000 miles on it. I will have to open it up to make sure its good to go. LMk if interested
I also have a non posi 3.42 drum rear end for 50.00 |
One more last question is the posi a 2.73 or the 3.27 either way I'm totally interested. |
kurfbird Member
Posted: Wed Apr 04, 2007 10:48 am Post subject: Its a 3.23 |
its a 3.23 rear end Everything looks the same. have part a non posi and the clamps for the ebrake and the routing look the same. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kenf729 Member
Posted: Wed Apr 04, 2007 10:57 am Post subject: |
great, and I assume when you say everything comes with it, it includes the calipers and break lines? if so I give you a call around the 20th to keep you posted.
Ken |
Posted: Wed Apr 04, 2007 11:08 am Post subject: |
| as long as you have the same brakes the cables will be identical. if you are going from drum to disc or something the cables are available from napa/scmhucks/bastards/vato-zone for -+15.00 |
kenf729 Member
Posted: Wed Apr 04, 2007 11:10 am Post subject: |
thanks going from Drum to disk, so I would need the cables then...I really appreciate this site lots of helpful information here...
Ken |
kurfbird Member
Posted: Wed Apr 04, 2007 11:20 am Post subject: The rear end comes with the cables |
The rear end comes with the cables. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kurfbird Member
Posted: Wed Apr 04, 2007 11:21 am Post subject: Everything |
Yes calipers, brake lines, rotors, backing plate, brake cables, pads. etec etc etc _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kenf729 Member
Posted: Wed Apr 04, 2007 11:44 am Post subject: |
| sweet, consider it sold... |
kurfbird Member
Posted: Wed Apr 04, 2007 12:36 pm Post subject: Okay |
Okay
Just Let me know if you change your mind. I am going to open it up this weekend and check the gears. etc. Will let you know the results _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
