Cascade Crew Message Forums
scott in wa. Member
1988 Chevrolet Camaro IROC-Z
Posted: Fri Apr 07, 2006 9:31 am Post subject: RPO Codes |
1988 Camaro RPO codes from new car.
I may have a few wrong and also missed a few, I will check again tonight.
But here is the list..
so Far not a iroc, I saw the code for the group but didn't write it down, I will tonight.
Interesting stuff
Code option #of price
1FP87 Camaro IROC-Z Convertible, 8-cylinder 3,761 18,015
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 Power Door Locks 44,019 145
A01 Tinted Glass, all windows 91,069 120
A31 Power Windows 60,662 210
B18 : ORNAMENTATION, INTR, DELUX
B34 Floor Mats, carpet insert two front 56,174 *
B35 Floor Mats, carpet insert, two rear 56,178 *
B84 Moldings, body side 80,990 60
B91 Moldings, door edge (black) 16,097 15
CD4 Windshield Wipers, intermittent 59,402 *
C60 Air Conditioning 88,431 775
D35 : MIRROR, OUTSIDE REAR VIEW
D6D : COLOR OVERRIDE, TRIM AND PAINT COMPATABILITY
D88 : DECAL, STRIPE, SPORT
F5Z
E9Z : SPEEDOMETER KEY (DELETE)
GU2 : AXLE REAR, 2.73 RATIO
J50 : BRAKE SYSTEM, POWER
K34 Speed Control, with resume 56,692 *
K60 : GENERATOR, 100 AMP
L03 Engine, 305ci, 170hp (for Sport Coupe) 28,719 400
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
MX0 Transmission, automatic with overdrive 77,179 490
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NK3 : STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
N33 Tilt Steering Column 59,403 *
N65 : WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N90 : WHEEL, 15 X 7,ALUMINUM CAST,4.75 INCH BOLT CIRCLE
QYZ Tires, P215/65R15 blackwall 77,466 *
TR9 Lighting, auxiliary 35,844 *
TT4 Headlamps, halogen (4) 26,885 *
UM6 Radio, stereo, cassette, clock, seek/scan 52,824 *
UQ1 : RADIO PROVISIONS, FOR STEREO
U25
U26
U29
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
WW2 : APPEARANCE PACKAGE(SILVER), AERO #2
W62 : ORNAMENTATION, AERO PACKAGE
YR1 : SEAT,FRT CUSTOM
YS1
YT1 : BUILD UP DR & QTR
Z08 : MODEL CONVERSION, CONVERTIBLE
1AY : 1AY: Stock Orders Processing Option (DEALER ORDERED CAR)
ISD
I69
19C : TRIM COMBINATION, CLOTH, BLACK (C) (91)
19I : INTERIOR TRIM, BLACK (I) (91)
I9T
199 : SEAT BELT COLOR, BLACK (91)
12Q : MOLDING COLOR, SILVER MET (91)
23U : PRIMARY COLOR, EXTERIOR, MED MAUI BLUE MET (91)
6XW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
BUY
86A : STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
9UY : SPRING, COMPUTER SELECTED, REAR, RIGH |
Posted: Fri Apr 07, 2006 10:09 am Post subject: |
| Ew.... ditch that 2.73 rear end if that's still what's in it. |
scott in wa. Member
Posted: Fri Apr 07, 2006 10:39 am Post subject: yep |
I think we are going to swap out rears; the other car is a bit better.
soon I will be pulling a a bunch of parts off of the other car, 87 z28 and trying to sell them.
went down and tried to put the car into my name, I gave them a receipt for $600, they said no way, car is worth 2200 to 4400, I flipped a gored.
They say to go get an estimate on whet it will cost to fix it and take it off the 2200 dolor amount.
So I went and saw a shop I know and Iam getting a quote to get a new tranni in it, that should be about 2400 bucks.
But I can't believe how tight they bare getting on sales tax.
They also said it is a Iroc, when they punched up the numbers.
Scott |
Posted: Fri Apr 07, 2006 10:41 am Post subject: |
| Just defend your case. If you got it for $600 say the engine's got problems and such. if that's the bill of sale, they CANNOT refuse to let you license it. |
Posted: Fri Apr 07, 2006 10:45 am Post subject: |
| ok, trying to understand washingtons laws. you showed them the recipt from the car you purchased for 600, and they said it is worth way more then that, cause they want you to pay more tax? that sucks now, but if anyone ever wrecks it and the insurance company wants to give you 600 you can tell them the state of WA says it's worth 4200. |
scott in wa. Member
Posted: Fri Apr 07, 2006 10:54 am Post subject: taxes |
Yep that’s about it, they said I have to provide another piece of paper from the seller, not the receipt. Something else. I don't have his number anymore anyway.
I even had them call Olympia so they could find out the previous cost of the car, (bought at auction) everything jived, but still no go.
They said, that’s the law, its a state thing. Trying to get more money. the receipt wasn't enough. Yes I HAD A COW RIGHT THERE.
Or go get a estimate of repair, so that’s what I did. I know someone in the business.
Stupid stuff, they have sure messed things up......
Hey maybe the state wants it for 2200????????
Shoot, next is emissions.....I bet it passes. |
kurfbird Member
Posted: Fri Apr 07, 2006 11:26 am Post subject: paperwork |
The paper work that your talking about is from the DMV. I have a copy at home. You take that to the seller and list what is wrong with the car. Well Hint hint body work trans etc.
He sign it and DMV will not give you any problems. Did it once myself.
When I get home from work will look and see what it is called. _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
scott in wa. Member
Posted: Fri Apr 07, 2006 11:43 am Post subject: yep |
Ya I think I remember using it one time, But I don't have this guys number anymore anyway.
I had a problem because the receipt should be just as good.
It said, it needs Lots of work, not running.
And we both signed it. Shoot that would be enough for a Judge. |
Posted: Fri Apr 07, 2006 12:51 pm Post subject: |
Yeah thats what I did, I bought mine for 3000, but had them write a bill of sale for only 500 and say "it needs lots of work and is sold as is" I had no problems licensing it, cept the guy I bought it from wasn't actually the title holder but it is in my name now  _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
Posted: Fri Apr 07, 2006 3:11 pm Post subject: |
wow. They defiately didn't make me do anything like that for any of the cars I've bought, titled and licenced (but I also live in oregon). That's a pretty screwy law if you ask me. _________________
Posted: Fri Apr 07, 2006 3:13 pm Post subject: |
| We don't have to worry about it in Oregon, because we don't have sales tax. |
Posted: Fri Apr 07, 2006 3:45 pm Post subject: |
This is true.
Do they still have the RPO calculator or RPO decoder on TGO? Last couple times I've checked its not been there or not been working. _________________
Posted: Fri Apr 07, 2006 5:24 pm Post subject: |
| I had someone question me once and I just said it needs a new trans. Wrote me up fine. No "law this law that" bs. |
Nathan J Member
1986 Pontiac Firebird
Posted: Fri Apr 07, 2006 7:13 pm Post subject: |
just go in ask for the paper that you need, go home and have someone write it up for you there not going to no his handwriting and dont ask me how i no this =] _________________ 86 firebird
383sbc
th350 t brake
4th gen rear soon 9in ford rear |
scott in wa. Member
Posted: Sat Apr 08, 2006 9:08 am Post subject: done |
Got her done,
Cost 80 bucks.
Not including tabs.
Drove in this morning,
Pulls to the right pretty bad, need to take here in and have it checked out.
Rattles a bit as well.
Looks better than the other car, but looks can be deceiving.
Definitely needs some work.
But I guess we have a donor car.
Other motor will not be going in until something's are fixed. |
