carb conversion from tpi
LB985IROC
1995 Chevrolet Camaro Z/28
PostPosted: Sun Mar 26, 2006 8:45 pm    Post subject: carb conversion from tpi Reply with quote
so how hard would it be to remove my tpi and install a carburated fuel system???
Cadillac of Bellevue
Retail parts sales
vee-six
PostPosted: Sun Mar 26, 2006 9:45 pm    Post subject: Reply with quote
Paul, John? You guys wanna handle this one?
I"m assuming you're going with a mechanical/vaccum controled carb and not a computer controled Q-jet, right?
you'll have to remove your fuel rails, Intake plenum, Injectors..etc.. probably move your EGR or do away with it entirely.. you'll need a different fuel pump (probably) If you change fuel pumps, you'll need a different oil pressure sender unit, you'll need a vaccum modulated or HEI distributor and different coil. Perhaps a different fuel tank sender (not sure about that), different manifold, a TON of wiring to get rid of..That's what I know of.....I'm sure there's more....
LB985IROC
PostPosted: Sun Mar 26, 2006 10:03 pm    Post subject: Reply with quote
yea i fgiuured alot fo that so i do this and i can totally ditch my ecm? also i need ot know if i will have to go wiht a different fuel pump set up
Retail parts sales
vee-six
LB985IROC
PostPosted: Sun Mar 26, 2006 10:04 pm    Post subject: Reply with quote
need to get a new engine in my truck so i can park the iroc lol
Retail parts sales
vee-six
How come?
LB985IROC
PostPosted: Mon Mar 27, 2006 12:08 am    Post subject: Reply with quote
hydro locked it 4 wheelin
Retail parts sales
vee-six
PostPosted: Mon Mar 27, 2006 1:16 am    Post subject: Reply with quote
My camaro has a holley 4 barrel now and it used to be fuel injected so I'm in the middle of this project myself. It is a tough one because you have to get rid of all your old computer controled whatever, and that is a TON of wires let me tell you. Its going to take me a good weekend with my wiring diagram, a multimeter, lots of electrical tape and, lots of good ol' mechanic juice Very Happy they guy I bought it from started this project and now I get to finish it because the car is a bit tempramental electricly speaking, I wonder if it has to do with all the random wires all over my engine bay Confused Confused yuck
PostPosted: Mon Mar 27, 2006 11:19 am    Post subject: Reply with quote
http://www.thirdgen.org/tech/carbswap.shtml
LB985IROC
PostPosted: Mon Mar 27, 2006 3:03 pm    Post subject: Reply with quote
excellent we should make a big thing of this like with al's engine swap
Retail parts sales
vee-six
PostPosted: Mon Mar 27, 2006 3:59 pm    Post subject: Reply with quote
I'd be happy to help, but my swap was just me after the first 2 days (with a little help from the staff in the hobby shop Very Happy ). After the motor was in and sitting on the mounts, I was on my own to install the tranny and make all of the other connections. It was a learning process and I can't say I didn't enjoy it frustrating as it was at times. Smile
