well, got the Kenny Brown STB
miamivice
1982 Pontiac Trans Am
PostPosted: Sun Dec 11, 2005 7:51 pm    Post subject: well, got the Kenny Brown STB Reply with quote
I made a post on TGO but thought id post here as well for you suspension guys, i need help
http://thirdgen.org/techbb2/showthread.php?s=&threadid=335693
PostPosted: Mon Dec 12, 2005 11:49 am    Post subject: Reply with quote
Could be tons of factors. I'd probably try bending that A/C line out of the way. Looks like you're only a 1/2" off. Otherwise use some washers to lift it up. Make sure it clears your hood though! lol. Never seen that design from KB before.
PostPosted: Mon Dec 12, 2005 12:55 pm    Post subject: Reply with quote
thats the style i want.
PostPosted: Mon Dec 12, 2005 2:02 pm    Post subject: Reply with quote
I like the edelbrock better.
PostPosted: Mon Dec 12, 2005 2:31 pm    Post subject: Reply with quote
i ment the towere to tower to firewall style. not the KBSTB specifically. i will probably end up making my own.
PostPosted: Mon Dec 12, 2005 3:12 pm    Post subject: Reply with quote
I was going to make one to fit the HSR, but with some extra bracing on the subframes, I don't seem to need it.
PostPosted: Mon Dec 12, 2005 3:25 pm    Post subject: Reply with quote
you should still make one paul, it will help control the alightment, even though the chassis is stiff as it is.
PostPosted: Mon Dec 12, 2005 3:45 pm    Post subject: Reply with quote
HSR?
PostPosted: Mon Dec 12, 2005 3:52 pm    Post subject: Reply with quote
Holley Stealth Ram (the intake he is running.)
PostPosted: Mon Dec 12, 2005 4:01 pm    Post subject: Reply with quote
ooooohhhhh...... got it.
PostPosted: Mon Dec 12, 2005 7:55 pm    Post subject: Reply with quote
How much room do you have between the plenum and the hood?
miamivice
PostPosted: Mon Dec 12, 2005 11:24 pm    Post subject: Reply with quote
from what people said, the edelbrock one does not clear the firebird hood.
PostPosted: Tue Dec 13, 2005 1:01 am    Post subject: Reply with quote
Have you tried closing YOUR hood yet? That one looks just as tall as the edel Cool
miamivice
PostPosted: Thu Dec 15, 2005 2:06 pm    Post subject: Reply with quote
alright, just went out and was able to bend the ac line over to the left so the stb would clear.
fits just fine now and the hood clears just fine.
thanks alot
