miamivice Member
1982 Pontiac Trans Am
Posted: Mon Dec 12, 2005 11:49 am Post subject: |
| Could be tons of factors. I'd probably try bending that A/C line out of the way. Looks like you're only a 1/2" off. Otherwise use some washers to lift it up. Make sure it clears your hood though! lol. Never seen that design from KB before. |
Posted: Mon Dec 12, 2005 12:55 pm Post subject: |
| thats the style i want. |
Posted: Mon Dec 12, 2005 2:02 pm Post subject: |
| Xophertony wrote: | | thats the style i want. |
I like the edelbrock better. |
Posted: Mon Dec 12, 2005 2:31 pm Post subject: |
| i ment the towere to tower to firewall style. not the KBSTB specifically. i will probably end up making my own. |
Posted: Mon Dec 12, 2005 3:12 pm Post subject: |
| Xophertony wrote: | | i ment the towere to tower to firewall style. not the KBSTB specifically. i will probably end up making my own. |
I was going to make one to fit the HSR, but with some extra bracing on the subframes, I don't seem to need it. |
Posted: Mon Dec 12, 2005 3:25 pm Post subject: |
| you should still make one paul, it will help control the alightment, even though the chassis is stiff as it is. |
Posted: Mon Dec 12, 2005 3:45 pm Post subject: |
| HSR? |
Posted: Mon Dec 12, 2005 3:52 pm Post subject: |
| Holley Stealth Ram (the intake he is running.) |
Posted: Mon Dec 12, 2005 4:01 pm Post subject: |
| ooooohhhhh...... got it. |
Posted: Mon Dec 12, 2005 7:55 pm Post subject: |
| Twilightoptics wrote: | | Xophertony wrote: | | i ment the towere to tower to firewall style. not the KBSTB specifically. i will probably end up making my own. |
How much room do you have between the plenum and the hood? |
miamivice Member
Posted: Mon Dec 12, 2005 11:24 pm Post subject: |
| Twilightoptics wrote: | | Xophertony wrote: | | thats the style i want. |
from what people said, the edelbrock one does not clear the firebird hood. |
Posted: Tue Dec 13, 2005 1:01 am Post subject: |
Have you tried closing YOUR hood yet? That one looks just as tall as the edel  |
miamivice Member
Posted: Thu Dec 15, 2005 2:06 pm Post subject: |
| Twilightoptics wrote: | | Could be tons of factors. I'd probably try bending that A/C line out of the way. Looks like you're only a 1/2" off. Otherwise use some washers to lift it up. Make sure it clears your hood though! lol. Never seen that design from KB before. |
alright, just went out and was able to bend the ac line over to the left so the stb would clear.
fits just fine now and the hood clears just fine.
thanks alot |
