jchaussee Member
Posted: Sun Dec 02, 2012 2:19 pm Post subject: adhesives |
| So best adhesive for deck lid and best for t top and door seals. [/i] |
jchaussee Member
Posted: Sun Dec 02, 2012 2:19 pm Post subject: |
| And best way to get decklid off. |
Posted: Mon Dec 03, 2012 7:23 am Post subject: |
3m weatherstrip
A friend _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Mon Dec 03, 2012 7:53 am Post subject: |
| Should I heat up decklid first or just use a putty knife to break seal? |
jchaussee Member
Posted: Mon Dec 03, 2012 7:54 am Post subject: |
| And I have a box of the rope caulk. No good? |
Posted: Mon Dec 03, 2012 8:02 am Post subject: |
Must use hatch installation juice!
http://cascadecrew.org/phpBB2/viewtopic.php?t=8816&start=24
Once the hardware is off you can use the leverage of the decklid to break the seal. Maybe use a stiff putty knife but be careful of the edge of the glass.
Bear in mind that the seal between the glass and decklid is a completely submerged seal (you are essentially creating the bottom of a rain trough) so you need to use some serious business to seal it. I made the mistake of using some GE2 silly-cone on John's and it leaked badly.  |
Posted: Mon Dec 03, 2012 6:31 pm Post subject: |
I thought we were talking weather stripping for the deck lid..... not the lid vs glass piece. Don't use weatherstrip adhesive.
Get some 3M Glass adhesive. For glueing windows in. _________________ A redline a day keeps the carbon away! |
Posted: Mon Dec 03, 2012 6:40 pm Post subject: |
| aaron_sK wrote: |
Still leaking in fact!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Mon Dec 03, 2012 7:13 pm Post subject: |
| Paul, does that glass adhesive have much body to it? The factory sealant that GM used basically looks like roofing tar. It's very thick and stays pliant. |
Posted: Mon Dec 03, 2012 7:14 pm Post subject: |
Yep, it's rather thick, very sticky. It's what I used to glue the side windows in the mazda. Worked freakin' awesome.
You want the thickness to fill all those gaps. _________________ A redline a day keeps the carbon away! |
Posted: Mon Dec 03, 2012 7:20 pm Post subject: |
Cool beans. There are some large gaps between the decklid and glass just by it's design. |
