adhesives
jchaussee
PostPosted: Sun Dec 02, 2012 2:19 pm    Post subject: adhesives Reply with quote
So best adhesive for deck lid and best for t top and door seals. [/i]
jchaussee
PostPosted: Sun Dec 02, 2012 2:19 pm    Post subject: Reply with quote
And best way to get decklid off.
PostPosted: Mon Dec 03, 2012 7:23 am    Post subject: Reply with quote
3m weatherstrip
A friend
jchaussee
PostPosted: Mon Dec 03, 2012 7:53 am    Post subject: Reply with quote
Should I heat up decklid first or just use a putty knife to break seal?
jchaussee
PostPosted: Mon Dec 03, 2012 7:54 am    Post subject: Reply with quote
And I have a box of the rope caulk. No good?
PostPosted: Mon Dec 03, 2012 8:02 am    Post subject: Reply with quote
Must use hatch installation juice! Cool
http://cascadecrew.org/phpBB2/viewtopic.php?t=8816&start=24
Once the hardware is off you can use the leverage of the decklid to break the seal. Maybe use a stiff putty knife but be careful of the edge of the glass.
Bear in mind that the seal between the glass and decklid is a completely submerged seal (you are essentially creating the bottom of a rain trough) so you need to use some serious business to seal it. I made the mistake of using some GE2 silly-cone on John's and it leaked badly. Embarassed
PostPosted: Mon Dec 03, 2012 6:31 pm    Post subject: Reply with quote
I thought we were talking weather stripping for the deck lid..... not the lid vs glass piece. Don't use weatherstrip adhesive.
Get some 3M Glass adhesive. For glueing windows in.
PostPosted: Mon Dec 03, 2012 6:40 pm    Post subject: Reply with quote
Still leaking in fact! Sad
PostPosted: Mon Dec 03, 2012 7:13 pm    Post subject: Reply with quote
Paul, does that glass adhesive have much body to it? The factory sealant that GM used basically looks like roofing tar. It's very thick and stays pliant.
PostPosted: Mon Dec 03, 2012 7:14 pm    Post subject: Reply with quote
Yep, it's rather thick, very sticky. It's what I used to glue the side windows in the mazda. Worked freakin' awesome.
You want the thickness to fill all those gaps.
PostPosted: Mon Dec 03, 2012 7:20 pm    Post subject: Reply with quote
Cool beans. Cool There are some large gaps between the decklid and glass just by it's design.
