i need v6 owners advice
Goto page Previous  1, 2, 3  Next
BluFbdy
PostPosted: Tue Apr 17, 2012 10:31 pm    Post subject: Reply with quote
Beyond this one I've worked on one other v6 lol everyone I know has a v8 with a few crewbies being the exception my tinkering is on hold til Thursday, I got absolutely screwed at work and I close every night, attempted working on it today and I was a half hour late to work Laughing I pulled out some 4 gauge wire and a fuse, followed by a 200amp stinger circuit breaker less than 12 inches away... Apparently they wanted to protect the 200 amp breaker with a 60 amp fuse....
BluFbdy
PostPosted: Thu Apr 19, 2012 2:13 pm    Post subject: Reply with quote
Checked the timing on the proper cylinder and it was still spot on at 10*.... So idk wtf is up with that, readjusted the tps it was reading .60 at rest and then reset minimum air, checked the firing order and #6 and#3 were backwards. Runs a lot better now but its still just loud lol anything I can do to give this thing some more torque? Without major modifications
PostPosted: Thu Apr 19, 2012 2:57 pm    Post subject: Reply with quote
If you timed it with the drivers side to 10deg BTDC, and you put the light on the front passenger side, it shouldn't have been at 10deg BTDC.
PostPosted: Thu Apr 19, 2012 2:59 pm    Post subject: Reply with quote
700R4 or T5? I'd like to hear some performance metrics so we can evaluate whether you're seeing a normal amount of power or not. You could just be not used to a 2.8. Wink
BluFbdy
PostPosted: Thu Apr 19, 2012 3:17 pm    Post subject: Reply with quote
Honest to god Paul it was at 10* without adjustment, the distributor hold down was also loose when I got it and I just tightened it down.
It's got a 700r4 on it I'm sure its the not being used to it thing, I just wish it had some power of any kind lol I'd do a t5 swap but its my wifes car and we bought it for the auto lol
PostPosted: Thu Apr 19, 2012 4:10 pm    Post subject: Reply with quote
Now that's some solid reasoning. Laughing
But I totally agree, something seems fishy here. Are you 100% certain that you have the right mark on the balancer, the right mark on the timing pointer and the EST unhooked?
BluFbdy
PostPosted: Thu Apr 19, 2012 4:33 pm    Post subject: Reply with quote
Is hope there's only one mark on the balancer, the est was unhooked and I had trouble with the timing tab because I couldn't see the numbers unless I wiped it with a wrt rag, they'd fade once it dried so I made a mark with my hook tool at 10, I may have sscrewed up the first time around d but its running pretty damn smooth now and no sluggish response
PostPosted: Thu Apr 19, 2012 5:45 pm    Post subject: Reply with quote
There is only 1 mark on the v6 bal. But I have heard several storys of them spinning. If you have time, set the thing manually to 1TDC and see where your balancer mark is. Also, the v6 is known for eating timing chains, see how much slop is in that chain. They are to be replaced at 30-40k.
The 700r4 just robs power on that v6. I swapped to a t5 and it was like night and day!!!
Otherwise, your trying to move a giant brick with 125hp, and 160?? tq. Imagine what the few with the iron duke 4cyl feels like.
PostPosted: Thu Apr 19, 2012 5:47 pm    Post subject: Reply with quote
Yup.
PostPosted: Thu Apr 19, 2012 5:57 pm    Post subject: Reply with quote
IIRC it's the timing chain tensioner that fails on those motors.
I'll 100% agree with the weight and the 700R4 issue. I could blow my brother's 3.1/700R4 Firebird out of the water with my 2.8/5-speed Cavalier. 2700lbs vs. 3600lbs. Wink
PostPosted: Thu Apr 19, 2012 6:12 pm    Post subject: Reply with quote
For my 3.1, it was the nylon tips on the gears that wore down and let the chain fall off. This was a few thousand miles before the thrust bearing went away and the motor ultimately replaced.
BluFbdy
PostPosted: Fri Apr 20, 2012 3:12 pm    Post subject: Reply with quote
Balls. It never gets easy does it? Lol so what all is involved with checking/ replacingthe chain on this thing? I need to replace the valve guides on it but I'm afraid to do it without someone's help who knows what they're doing, I've always just had hem replaced when I get the heads worked but I wanna do it on the motor, I know there's a possibility that the valve can drop in but I wanna do the string trick
PostPosted: Fri Apr 20, 2012 3:41 pm    Post subject: Reply with quote
You absolutely cannot replace valve guides on the engine.
Seals yes, but you'll want an air compressor, spark plug fitting for compressor, valve spring compressor for your native motor.
Timing chain? I can't remember if the pan has to come off, but the whole from the of the motor to pull the timing cover off.
BluFbdy
PostPosted: Fri Apr 20, 2012 6:32 pm    Post subject: Reply with quote
You understood what I meant lol I'm not liking the burning oil, that I can do at the house with some spare time but I'm not entirely sure I'm ready to tackle the chain ill check to see if it slipped but if its not I'm sweeping that under the rug for now lol
PostPosted: Fri Apr 20, 2012 9:07 pm    Post subject: Reply with quote
When you say it doesn't go anywhere, is it downshifting correctly? If the kickdown cable isn't adjust right it will hang at high WOT and not down shift. If you lift a little it will down shift and you will be on your way again. Just a thought.
BluFbdy
PostPosted: Fri Apr 20, 2012 10:47 pm    Post subject: Reply with quote
I'd like to readjust both cables the cable to shift it into gear is out of adjustment I have to shove it into park to get it to actually go into park lol it seems to downshift ok, I've only driven down the street, Monday its going into work with me so ill have a longer drive to actually evaluate its problems
PostPosted: Sat Apr 21, 2012 4:54 pm    Post subject: Reply with quote
There is no tensioner, just a guide. And when the chain gets sloppy, it chips the nylon off the guide.
BluFbdy
PostPosted: Mon Apr 23, 2012 4:15 pm    Post subject: Reply with quote
So I never checked the chain yet but I did drive it into work today, got the windshield replaced and a deck in it, carpets and seats are drying because I detailed it. The damn carpet was green O.o in any case on the drive it was hesitating under load, cruising at 45 through burley I had it steady and it was fluctating the rpms a bit, maybe 50-75, enough to hear it and slightly feel it
PostPosted: Mon Apr 23, 2012 4:37 pm    Post subject: Reply with quote
Could be fuel, could be O2, could be vacuum leak.
BluFbdy
PostPosted: Mon Apr 23, 2012 10:39 pm    Post subject: Reply with quote
Well I found out there's no thermostat. And it takes forever and a day to warm up, not seeing the fan kick on either idk if its just jot getting hot enough or if its screwed also. The pigtail for the gauge is totally jacked so I have no idea what the temp is.
Gotta fix the pigtail and do more t shooting, I'm not throwing anycodes for anything I checked after every drive today I guess I can check fuel pressure for the hell of it,
Page 2 of 3
