Kage87Z Member
1969 Chevrolet Camaro
Posted: Sat May 28, 2005 3:59 pm Post subject: Anyone in the Vanc area set up a ring and pinion? |
My 69 is very fast... tho I have no idea how fast...
and a big part of it has to be the rear end... which I would guess is in the 4.56 range... 12 bolt.
At 5 MPG, trips are few and far between. So... I'm thinking about swapping that out for a 2.73.
I know about as much about setting up a rear end as I do brain surgery.
Anyone in this neck of the woods able to do this?
What would it run me to have this done? Any recommendations? _________________ "Are you guys ready? Let's roll."
Todd Beamer - 9/11
Never Forget
Demon 12sec Club
Posted: Sat May 28, 2005 6:51 pm Post subject: |
probably 200 bucks to have it done if you provide the parts...
www.randysringandpinion.com would be your best bet IMO for parts _________________
Soon to be less than stock |
Posted: Sat May 28, 2005 7:07 pm Post subject: |
You're lookin at $150+ for the ring/pinion
And another $100+ for a rebuild kit.
You'll want axle bearings/seals because you're already there.
$5 for gear oil, another like $7 for Limited Slip Lube (if you have a posi, and get it from GM dealer).
If you do it yourself.
Try calling I5 Driveline, great bunch of guys. Probably run you around $500 to have them do it. |
ET phone hoME Member
Posted: Sat May 28, 2005 8:02 pm Post subject: |
2.73?? why not a 3.73? i have a 3.73 and the mileage is about as good as it would get with any lesser. from what i have gathered its when you get into the 4.x that kills the mileage more than anything. _________________ 1990 Camaro RS, Black w/ Red Int, V6 3.1L, Auto, T-Tops. |
Posted: Sat May 28, 2005 8:11 pm Post subject: |
| ET phone hoME wrote: | | 2.73?? why not a 3.73? i have a 3.73 and the mileage is about as good as it would get with any lesser. from what i have gathered its when you get into the 4.x that kills the mileage more than anything. |
WHOA WHOA WHOA DUDE.....
I went from 3.23 to 3.73 and went from 16mpg to 11 on a GOOD day. |
Demon 12sec Club
Posted: Sat May 28, 2005 8:17 pm Post subject: |
| ET phone hoME wrote: | | 2.73?? why not a 3.73? i have a 3.73 and the mileage is about as good as it would get with any lesser. from what i have gathered its when you get into the 4.x that kills the mileage more than anything. | think of the power he is pushing through a tranmission without an overdrive.
not to mention, its a bigblock engine.
you more than likely have an overdrive.
3.73 from 3.23 isn't going to be that drastic for you.
if he's going from 4.xx or 3.xx to a 2.xx ... I think he'll be better off.
short of getting a gear vendors (which has crossed his mind i'm sure), cheapest way to do it is a new gear ratio _________________
Posted: Sat May 28, 2005 8:58 pm Post subject: |
| Demon wrote: | | ET phone hoME wrote: | | 2.73?? why not a 3.73? i have a 3.73 and the mileage is about as good as it would get with any lesser. from what i have gathered its when you get into the 4.x that kills the mileage more than anything. | think of the power he is pushing through a tranmission without an overdrive.
short of getting a gear vendors (which has crossed his mind i'm sure), cheapest way to do it is a new gear ratio |
I don't have an overdrive. And it was that drastic for me. I was just showing ET that small changes can make a large difference. I'm also putting out decent power. |
Demon 12sec Club
Posted: Sat May 28, 2005 9:18 pm Post subject: |
| Twilightoptics wrote: | | Demon wrote: | | ET phone hoME wrote: | | 2.73?? why not a 3.73? i have a 3.73 and the mileage is about as good as it would get with any lesser. from what i have gathered its when you get into the 4.x that kills the mileage more than anything. | think of the power he is pushing through a tranmission without an overdrive.
I don't have an overdrive. And it was that drastic for me. I was just showing ET that small changes can make a large difference. I'm also putting out decent power. | never said you did have one.  _________________
Posted: Sat May 28, 2005 10:29 pm Post subject: |
i have OD _________________ 1990 Camaro RS, Black w/ Red Int, V6 3.1L, Auto, T-Tops. |
Kage87Z Member
Posted: Sun May 29, 2005 11:10 am Post subject: |
| Demon wrote: |
Oh, yeah... I've checked out gear vendors and, at some point may go that route... but it's a $2500 or so route to go.
I-5 driveline over at Lou's Machine Shop, right? _________________ "Are you guys ready? Let's roll."
Todd Beamer - 9/11
Never Forget
Posted: Sun May 29, 2005 11:36 am Post subject: |
| Kage87Z wrote: | | Demon wrote: |
I-5 driveline over at Lou's Machine Shop, right? |
Right. It's not Lou's anymore, he sold it to the head machinist Jim.. it's now called C's Machine. |
Kage87Z Member
Posted: Sun May 29, 2005 1:02 pm Post subject: |
| Twilightoptics wrote: | | Kage87Z wrote: | | Demon wrote: |
Really? What'd Lou wind up doing? Did he finally retire? _________________ "Are you guys ready? Let's roll."
Todd Beamer - 9/11
Never Forget
Posted: Sun May 29, 2005 1:04 pm Post subject: |
| Kage87Z wrote: | | Twilightoptics wrote: | | Kage87Z wrote: | | Demon wrote: |
Really? What'd Lou wind up doing? Did he finally retire? |
I was seeing Lou over at the driveline and the repair shop. He's still out there! |
