Random picture
Goto page Previous  1, 2, 3
PostPosted: Mon Nov 21, 2011 9:32 pm    Post subject: Reply with quote
Your engine compartment looks a bit different than mine. Lots of little stuff are different. Whats on your wiper module?
PostPosted: Mon Nov 21, 2011 9:38 pm    Post subject: Reply with quote
its the stock super old azz early thirdgen style.
I really like the look of your 4th gen master cyl.
PostPosted: Mon Nov 21, 2011 9:43 pm    Post subject: Reply with quote
4th gen is an easy swap. You have to redo the rear coupler. Might as well do an adjustable prop valve while your at it. Thats also where I put my power steering resevoir!
PostPosted: Mon Nov 21, 2011 9:50 pm    Post subject: Reply with quote
nice! I already have an adjustable rear prop valve from the disc swap i did. i just like the smaller looking reservoir. And i've got to say the engine bay looks pretty nice. not a lot of wires and random crap everywhere. Now it just needs a supercharger!
I'm pretty happy with how clean i was able to make the LT1 swap look in the end. Most LT1 swaps i've seen look pretty hacked up.
PostPosted: Mon Nov 21, 2011 10:02 pm    Post subject: Reply with quote
PLEASE.... move your air filter......
PostPosted: Tue Nov 22, 2011 8:38 am    Post subject: Reply with quote
I agree. I did mine on the cheap with marine exhause hose and sewer pipe. Ghetto! But it was functional. I will say this from my experience with maf run deisels, keep as straight a path as possible leading up to the maf and protect the maf from rattling against things. For our application, we needed nearly 2 feet of straight pipe before the maf to help the air straighten out.
PostPosted: Tue Nov 22, 2011 10:08 am    Post subject: Reply with quote
Thats a very clean LT1 swap. But I agree, gotta move the filter.
PostPosted: Tue Nov 22, 2011 8:51 pm    Post subject: Reply with quote
i plan on it. I've been more worried about getting the thing running right and working the bugs out. but now that this thing runs like a champ, i plan on fixing that soon.
PostPosted: Fri Nov 25, 2011 11:10 am    Post subject: Reply with quote
Jackpot. Very Happy
PostPosted: Fri Nov 25, 2011 12:14 pm    Post subject: Reply with quote
Well I'll be damned...
PostPosted: Fri Nov 25, 2011 10:43 pm    Post subject: Reply with quote
Very Happy
PostPosted: Sat Nov 26, 2011 4:55 am    Post subject: Reply with quote
Help me out here, what is jackpot? Are those turbo headers? V8 swap headers for the bimmer?
PostPosted: Sat Nov 26, 2011 5:19 am    Post subject: Reply with quote
They appear to have v-band flanges, so I am thinking turbo.
PostPosted: Sat Nov 26, 2011 8:27 am    Post subject: Reply with quote
They're forward facing LQ/LS headers, Jake. That oughta tell you all you need to know. Wink
Ian who made that set? I don't recognize the design or the 'SP' tag on the pass. side.
PostPosted: Sat Nov 26, 2011 10:15 am    Post subject: Reply with quote
Looks like they're from a company called "Spoolin' Performance". I picked them up used with supposedly under a thousand miles.
http://www.spoolinperformance.com/tubular-header-starters-p-751.html
PostPosted: Sat Nov 26, 2011 10:18 am    Post subject: Reply with quote
Never trust any company with an apostrophe in their name. Razz
PostPosted: Sat Nov 26, 2011 7:24 pm    Post subject: Reply with quote
down and forward?!? Are you going to have to run an oil sump, or is there still a chance to gravity drain the oil straight to the oil-pan?
PostPosted: Sat Nov 26, 2011 8:45 pm    Post subject: Reply with quote
nice! I figured thats what they were, since i thought you already had long tubes for the 5.3.
When do the rest of the parts arrive? and are you planning on running 1 or 2 hamsters?
PostPosted: Sat Nov 26, 2011 11:10 pm    Post subject: Reply with quote
It "says" down and forward but it's not as down and forward as the stainless works headers. They're equal, if not a bit higher, than the exhaust ports themselves with the collectors pointed slightly up. I may swap their sides if it clears the PS pump or I can run a remote reservoir. I'm dreading dealing with the oil returns. If I have to run it to the pan I'll need to pull the motor to tap it. Sad
Yeah and unfortunately my LTs are pretty beat up so I won't be able to get the kind of coin out of my current exhaust as I was hoping. Sad Sticking with one snail for now since I have it. May opt for twins later if I go 6.2 or larger. Still on the hunt for good used stuff. I'm a cheapass. Very Happy
Page 3 of 3
