Posted: Mon Nov 21, 2011 9:32 pm Post subject: |
| Your engine compartment looks a bit different than mine. Lots of little stuff are different. Whats on your wiper module? |
Posted: Mon Nov 21, 2011 9:38 pm Post subject: |
its the stock super old azz early thirdgen style.
I really like the look of your 4th gen master cyl. |
Posted: Mon Nov 21, 2011 9:43 pm Post subject: |
| 4th gen is an easy swap. You have to redo the rear coupler. Might as well do an adjustable prop valve while your at it. Thats also where I put my power steering resevoir! |
Posted: Mon Nov 21, 2011 9:50 pm Post subject: |
nice! I already have an adjustable rear prop valve from the disc swap i did. i just like the smaller looking reservoir. And i've got to say the engine bay looks pretty nice. not a lot of wires and random crap everywhere. Now it just needs a supercharger!
I'm pretty happy with how clean i was able to make the LT1 swap look in the end. Most LT1 swaps i've seen look pretty hacked up.
~JAKE |
Posted: Mon Nov 21, 2011 10:02 pm Post subject: |
PLEASE.... move your air filter...... _________________ A redline a day keeps the carbon away! |
Posted: Tue Nov 22, 2011 8:38 am Post subject: |
I agree. I did mine on the cheap with marine exhause hose and sewer pipe. Ghetto! But it was functional. I will say this from my experience with maf run deisels, keep as straight a path as possible leading up to the maf and protect the maf from rattling against things. For our application, we needed nearly 2 feet of straight pipe before the maf to help the air straighten out. _________________ E30
Posted: Tue Nov 22, 2011 10:08 am Post subject: |
| Thats a very clean LT1 swap. But I agree, gotta move the filter. |
Posted: Tue Nov 22, 2011 8:51 pm Post subject: |
i plan on it. I've been more worried about getting the thing running right and working the bugs out. but now that this thing runs like a champ, i plan on fixing that soon.
~JAKE |
Posted: Fri Nov 25, 2011 11:10 am Post subject: |
Jackpot.
Posted: Fri Nov 25, 2011 12:14 pm Post subject: |
| Well I'll be damned... |
Posted: Fri Nov 25, 2011 10:43 pm Post subject: |
 _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sat Nov 26, 2011 4:55 am Post subject: |
| Help me out here, what is jackpot? Are those turbo headers? V8 swap headers for the bimmer? |
Posted: Sat Nov 26, 2011 5:19 am Post subject: |
| They appear to have v-band flanges, so I am thinking turbo. |
Posted: Sat Nov 26, 2011 8:27 am Post subject: |
They're forward facing LQ/LS headers, Jake. That oughta tell you all you need to know.
Ian who made that set? I don't recognize the design or the 'SP' tag on the pass. side. |
Posted: Sat Nov 26, 2011 10:18 am Post subject: |
Never trust any company with an apostrophe in their name.  |
Posted: Sat Nov 26, 2011 7:24 pm Post subject: |
| down and forward?!? Are you going to have to run an oil sump, or is there still a chance to gravity drain the oil straight to the oil-pan? |
Posted: Sat Nov 26, 2011 8:45 pm Post subject: |
nice! I figured thats what they were, since i thought you already had long tubes for the 5.3.
When do the rest of the parts arrive? and are you planning on running 1 or 2 hamsters? |
Posted: Sat Nov 26, 2011 11:10 pm Post subject: |
| Dewey316 wrote: | | down and forward?!? Are you going to have to run an oil sump, or is there still a chance to gravity drain the oil straight to the oil-pan? |
It "says" down and forward but it's not as down and forward as the stainless works headers. They're equal, if not a bit higher, than the exhaust ports themselves with the collectors pointed slightly up. I may swap their sides if it clears the PS pump or I can run a remote reservoir. I'm dreading dealing with the oil returns. If I have to run it to the pan I'll need to pull the motor to tap it.
| 83Z28BlackBetty wrote: | nice! I figured thats what they were, since i thought you already had long tubes for the 5.3.
Yeah and unfortunately my LTs are pretty beat up so I won't be able to get the kind of coin out of my current exhaust as I was hoping. Sticking with one snail for now since I have it. May opt for twins later if I go 6.2 or larger. Still on the hunt for good used stuff. I'm a cheapass.  _________________
