Seattle Area Guys - Any one notice in the junk yard....
PostPosted: Thu Nov 10, 2011 9:28 am    Post subject: Seattle Area Guys - Any one notice in the junk yard.... Reply with quote
I need to find a 5speed trans from a metro or suzuki swift.
Anyone see one in the lakewood or tumwater yards? I've never been to either. What business are they?
Thanks
-Paul
PostPosted: Thu Nov 10, 2011 11:19 am    Post subject: Reply with quote
Did you check out www.car-part.com?
PostPosted: Thu Nov 10, 2011 1:23 pm    Post subject: Reply with quote
Yep. Car-part.com Closest trans is half the continent away.
Checked out the Lynnwood pick n pull today. They had 2 autos and 1 manual but the trans was gone.
I can get the parts I need (5th gear, slider, fork) for $450+tax!!!!!
Sigh.
PostPosted: Thu Nov 10, 2011 7:08 pm    Post subject: Reply with quote
I thought you'd allready fixed this?
PostPosted: Thu Nov 10, 2011 7:19 pm    Post subject: Reply with quote
Lakewood is Pick-N-Pull, they're owned by the same people who own the one in Lynnwood.
Tumwater is a private joint AFAIK, very relaxed and low prices. Selection kinda sucks though.
I'm probably going to be at the Lakewood yard after work tomorrow, shoot me a txt if you're free then.
PostPosted: Thu Nov 10, 2011 8:28 pm    Post subject: Reply with quote
www.woodfins.com shows 2 manual transmissions in their network. However, I dont see that they say where they are.
PostPosted: Thu Nov 10, 2011 9:22 pm    Post subject: Reply with quote
Work 130-10 aaron. Keep an eye out for me though.
I rebuilt the trans a year ago. She had a motor mount go out, and when the motor torqued it'd pull the shifter out of 5th. So she bungee corded the shifter to the dash to "keep it in gear." Which toasted the fork, slider and gear.
Good thing is you can access all of 5th gear in the car. 2 bolts drops the trans down far enough to get the side pan off. Couple 10mm bolts and a 2 studs unscrewed with vice grips. Small snap ring pliars and a roll pin driver to get the fork off, allen to take the detent cap off and a magnet to pull the ball out and you have all of 5th gear in your hands.
So long as it's a 33 tooth gear it'll work, otherwise I need the matching driven countershaft gear which requires a little more umph in the yard cause it's a nut like a half shaft hub nut.
PostPosted: Thu Nov 10, 2011 9:23 pm    Post subject: Reply with quote
Geo Metro 96 0001 10/12/2011
Geo Metro 92 0012 10/20/2011
Geo Metro 91 0011 10/24/2011
At Tacoma Pick N Pull
I assume this is "lakewood?"
PostPosted: Thu Nov 10, 2011 9:33 pm    Post subject: Reply with quote
Tacoma Pick-N-Pull = the old Lakewood Pull-A-Part.... Yeah I know. Laughing
I will hopefully get off work early enough to get out there. Am I correct in assuming that if any of these cars have a manual transmission that it will be the one you want?
PostPosted: Thu Nov 10, 2011 9:34 pm    Post subject: Reply with quote
Wow.. I thought you'd allready fixed this once. Sad
PostPosted: Thu Nov 10, 2011 9:58 pm    Post subject: Reply with quote
You want to look for some bmtroubleu stuff too? Very Happy
PostPosted: Thu Nov 10, 2011 10:02 pm    Post subject: Reply with quote
Rolling Eyes
PostPosted: Thu Nov 10, 2011 10:14 pm    Post subject: Reply with quote
Giving you a hard time, duder. Very Happy
PostPosted: Thu Nov 10, 2011 10:16 pm    Post subject: Reply with quote
What do you need out there?
PostPosted: Thu Nov 10, 2011 10:23 pm    Post subject: Reply with quote
Last time was a bearing failure. Thus episode is driver induced.
Aaron. It should be what I need. Just let me know if there is a stick and ill go sown sat am. If you feel the urge to.pull just grab the gear behind the pinch bolt if the gear with the synchro and slider is other than 33 teeth.
PostPosted: Thu Nov 10, 2011 10:32 pm    Post subject: Reply with quote
Ah realized you can read my statement a couple different ways. The driver enducement was definatly recognized. But nice Macgyver work with the bungee...
