Cast iron rear brakes
PostPosted: Sat Sep 10, 2011 8:54 pm    Post subject: Cast iron rear brakes Reply with quote
Got a wild hare to get this 9-bolt under the car so the 10 can go to the scrapyard and I can have one less thing in my shop that I am tripping over.
Unfortunately I scrapped the brakes off of it assuming I would be buying a kit, which is going to be a little further down the road. So I need cast iron calipers/rotors.pads. Not picky about condition as long as they are usable.
Can drive to you, or pay for shipping. Hit me up with price and what you have. Thanks.
PostPosted: Sun Sep 11, 2011 8:59 am    Post subject: Reply with quote
i have drums off a ten-bolt. I have everything. you can have it all.. as long as you take the rear end they are attached to. i want this thing out of my yard.
-Tony
PostPosted: Sun Sep 11, 2011 9:56 am    Post subject: Reply with quote
Disk brakes, Tony. Wink I have a 10-bolt with drums on the car now, and a 9-bolt on the floor of the shop with backing plates for the older-style disk brakes.
PostPosted: Sun Sep 11, 2011 10:28 am    Post subject: Reply with quote
If you can figure out how to re-drill them for the 9-bolt, I have a set of backing plates for the PBR disc brakes that you can have.
PostPosted: Tue Sep 13, 2011 5:26 pm    Post subject: Reply with quote
sucks, i just scrapped a car with a nine bolt and discs.. rear end was to rusty to even undo bolts.. but i bet i could have gotten the brakes off.
well, such is life
PostPosted: Tue Sep 13, 2011 6:42 pm    Post subject: Reply with quote
Same deal... I have a disc brake setup off of a 10 bolt....
PostPosted: Tue Sep 13, 2011 7:05 pm    Post subject: Reply with quote
I have the backing plates, Paul. I just need the calipers and rotors.
PostPosted: Tue Sep 13, 2011 9:01 pm    Post subject: Reply with quote
Do they run the 10bolt style caliper? If so..... we can make a deal :O)
PostPosted: Tue Sep 13, 2011 9:22 pm    Post subject: Reply with quote
TGO idiots seem to think so.
Only one real way to find out.
PostPosted: Tue Sep 13, 2011 9:36 pm    Post subject: Reply with quote
IIRC, Jake has them on his 9-bolt.
