Posted: Sat Nov 26, 2011 10:31 pm Post subject: Yesterdays happy fun time. |
I decided since it was dry that I would wash up the 'bird and wash off the engine bay at work, so I get it all cleaned up and go to start it and it just ran rough at idle, then stumbled and popped when I tried to hold it at 2K RPM. then when I moved it, it backfired, died and wouldn't start back up.
After about 10 minutes of cussing I decided to pop the dizzy cap off and found lots of corrosion, and the coil post was burnt on my MSD cap that is roughly a year old.
Luckly I work at Carr Chevy and the parts dept. was open for another 10 minutes and I was able to throw a new cap and rotor on and its driven great ever since, but I can't figure out what caused that, any ideas? _________________
'88 FORMULA |
Posted: Sun Nov 27, 2011 12:37 am Post subject: |
| Pacific northwest moisture. For years I had an Astro van that would be towed in once a year.. replace cap and away it went again. Some aftermarket caps have instructions with them to knock the vent screens out of the distributor. I don't think thats really the answer either. Only the small cap hei's seem to do this. Aluminum caps seem to be worse. |
Posted: Sun Nov 27, 2011 12:46 am Post subject: |
| chevymad wrote: | | Only the small cap hei's seem to do this. Aluminum caps seem to be worse. |
Every car I've owned that had a small cap with male contacts has gone to s**t fast. The worst was my Turd-a-bird with the 3.8. Tiny little dizzy and the cap would need to be replaced once or twice a year.
Big cap HEI fine, small cap with old-school female sockets also did fine.
Time for coilpacks.  |
IROCDave Member
Posted: Sun Nov 27, 2011 8:40 pm Post subject: |
| I know my MSD pro billet looked like it was in salt water two years after installing it. I cleaned the cap every spring and was shocked every time with the amount of crap on the posts / rotor. My car is rarely driven and is garaged. |
Posted: Sun Nov 27, 2011 11:34 pm Post subject: |
| Wow, maybe I just haven't noticed before... I use to replace my tune-up items more frequently.. |
BluFbdy Member
Posted: Mon Nov 28, 2011 12:06 am Post subject: |
I had an msd cap on mine that went to crap after a month and a half, caused alot of problems I'd get it swapped, I just replaced my whole dizzy to avoid any issues and its warrantied for life lol _________________ If you expect a kick to the balls and get a slap to the face its still a victory
