Posted: Tue Nov 15, 2011 3:37 pm Post subject: Hood skin |
| I picked up a cowl hood for.halfway cheap. Has a coiple dents and a crease which I can fix. But what I dont know how to fix is where the skin has popped up. Any ideas?? |
Posted: Tue Nov 15, 2011 5:57 pm Post subject: |
| gonna need pics for this |
Posted: Tue Nov 15, 2011 11:37 pm Post subject: |
| Hard to take pics. Basically it is delaminating from structure underneath in spots causing it to have high ' bubbles' |
Posted: Wed Nov 16, 2011 4:23 am Post subject: |
| Is it fiberglass? |
Posted: Wed Nov 16, 2011 8:00 am Post subject: |
| No steel |
Posted: Wed Nov 16, 2011 11:04 am Post subject: |
| Well upon closer inspection it looks as if I need to either screw down the locations or findbthe glue and figure out how to get it where I needs to go. Seems as if I may have got hustled on the Hood. |
Posted: Wed Nov 16, 2011 11:54 am Post subject: |
Spot weld. _________________ A redline a day keeps the carbon away! |
Posted: Wed Nov 16, 2011 12:02 pm Post subject: |
| That would be ideal but I lack knowledge and equipment. Nor division havevfunds to pay to have it done |
Posted: Wed Nov 16, 2011 12:04 pm Post subject: Re: Hood skin |
| jchaussee wrote: | | But what I dont know how to fix is where the skin has popped up. Any ideas?? |
Posted: Wed Nov 16, 2011 12:10 pm Post subject: |
| And I appreciate the ideas. I have called around to inquire about having it spot welded. But unfortunately the shops don't take my ravishing good looks or beer for payment |
IROCDave Member
Posted: Wed Nov 16, 2011 6:52 pm Post subject: |
| You could drill holes in it and have some one fill the holes with a wire feed. Might need to back the holes with sheet metal. There would be some repiar to smooth it out but should hold up. |
Posted: Wed Nov 16, 2011 7:06 pm Post subject: |
Aren't some auto body shops using epoxies to assemble body panels? I know there are some pretty strong epoxies out there to bond metals together. _________________ 92 Camaro
Posted: Wed Nov 16, 2011 7:44 pm Post subject: |
| Thats just what I need to find. It has some factory glue it looks like , bit it has come undone. Biggest challenge will be actually trying to get epoxy in right place |
Posted: Wed Nov 16, 2011 8:08 pm Post subject: |
Yes, and that glue is by 3m.
Ive never heard the term "delamitating" in reference to steel.
But welding would be best. After its pouned back in place. |
Posted: Wed Nov 16, 2011 8:21 pm Post subject: |
| 91RSVert wrote: |
Common term in the welding world. _________________ A redline a day keeps the carbon away! |
Posted: Wed Nov 16, 2011 8:36 pm Post subject: |
Not a term I associated with welding either. Does it mean the same as in layers seperating? or does it just mean the weld is coming apart.
I think you'll find the epoxy will cost more then just having it welded. The autobody epoxies i've seen require an expensive applicator setup. That and I just cant imagine welding costing that much. It's the work after the welding that would take alot of time. |
Posted: Wed Nov 16, 2011 8:44 pm Post subject: |
Separation of layers. _________________ A redline a day keeps the carbon away! |
Posted: Wed Nov 16, 2011 9:08 pm Post subject: |
| Yes. Seperation of layers. Yeah I am going to call a few shops tonmorow. Cant finish resy of body work untill the humps are taken care of. Makes it hard to have a smooth area |
Posted: Thu Nov 17, 2011 12:07 pm Post subject: |
I have never see this. Even when i removed the structure from under the hood mine stayed flat. It sounds like someone sat on your hood and stretched the metal. I wouldnt spot weld it if thats the case. It would look better but still not good. Try to find a new hood. Picture would help. _________________ E30
BluFbdy Member
Posted: Fri Nov 18, 2011 1:18 am Post subject: |
| blue89 wrote: | | I have never see this. Even when i removed the structure from under the hood mine stayed flat. It sounds like someone sat on your hood and stretched the metal. I wouldnt spot weld it if thats the case. It would look better but still not good. Try to find a new hood. Picture would help. |
Nick (nonsensekid) has an extra rs hood I believe that might be a better route than repairing, its not a cowl but it would work _________________ If you expect a kick to the balls and get a slap to the face its still a victory
