Hood skin
jchaussee
PostPosted: Tue Nov 15, 2011 3:37 pm    Post subject: Hood skin Reply with quote
I picked up a cowl hood for.halfway cheap. Has a coiple dents and a crease which I can fix. But what I dont know how to fix is where the skin has popped up. Any ideas??
PostPosted: Tue Nov 15, 2011 5:57 pm    Post subject: Reply with quote
gonna need pics for this
jchaussee
PostPosted: Tue Nov 15, 2011 11:37 pm    Post subject: Reply with quote
Hard to take pics. Basically it is delaminating from structure underneath in spots causing it to have high ' bubbles'
PostPosted: Wed Nov 16, 2011 4:23 am    Post subject: Reply with quote
Is it fiberglass?
jchaussee
PostPosted: Wed Nov 16, 2011 8:00 am    Post subject: Reply with quote
No steel
jchaussee
PostPosted: Wed Nov 16, 2011 11:04 am    Post subject: Reply with quote
Well upon closer inspection it looks as if I need to either screw down the locations or findbthe glue and figure out how to get it where I needs to go. Seems as if I may have got hustled on the Hood.
PostPosted: Wed Nov 16, 2011 11:54 am    Post subject: Reply with quote
Spot weld.
jchaussee
PostPosted: Wed Nov 16, 2011 12:02 pm    Post subject: Reply with quote
That would be ideal but I lack knowledge and equipment. Nor division havevfunds to pay to have it done
PostPosted: Wed Nov 16, 2011 12:04 pm    Post subject: Re: Hood skin Reply with quote
jchaussee
PostPosted: Wed Nov 16, 2011 12:10 pm    Post subject: Reply with quote
And I appreciate the ideas. I have called around to inquire about having it spot welded. But unfortunately the shops don't take my ravishing good looks or beer for payment
IROCDave
PostPosted: Wed Nov 16, 2011 6:52 pm    Post subject: Reply with quote
You could drill holes in it and have some one fill the holes with a wire feed. Might need to back the holes with sheet metal. There would be some repiar to smooth it out but should hold up.
PostPosted: Wed Nov 16, 2011 7:06 pm    Post subject: Reply with quote
Aren't some auto body shops using epoxies to assemble body panels? I know there are some pretty strong epoxies out there to bond metals together.
jchaussee
PostPosted: Wed Nov 16, 2011 7:44 pm    Post subject: Reply with quote
Thats just what I need to find. It has some factory glue it looks like , bit it has come undone. Biggest challenge will be actually trying to get epoxy in right place
PostPosted: Wed Nov 16, 2011 8:08 pm    Post subject: Reply with quote
Yes, and that glue is by 3m.
Ive never heard the term "delamitating" in reference to steel.
But welding would be best. After its pouned back in place.
PostPosted: Wed Nov 16, 2011 8:21 pm    Post subject: Reply with quote
Common term in the welding world.
PostPosted: Wed Nov 16, 2011 8:36 pm    Post subject: Reply with quote
Not a term I associated with welding either. Does it mean the same as in layers seperating? or does it just mean the weld is coming apart.
I think you'll find the epoxy will cost more then just having it welded. The autobody epoxies i've seen require an expensive applicator setup. That and I just cant imagine welding costing that much. It's the work after the welding that would take alot of time.
PostPosted: Wed Nov 16, 2011 8:44 pm    Post subject: Reply with quote
Separation of layers.
jchaussee
PostPosted: Wed Nov 16, 2011 9:08 pm    Post subject: Reply with quote
Yes. Seperation of layers. Yeah I am going to call a few shops tonmorow. Cant finish resy of body work untill the humps are taken care of. Makes it hard to have a smooth area
PostPosted: Thu Nov 17, 2011 12:07 pm    Post subject: Reply with quote
I have never see this. Even when i removed the structure from under the hood mine stayed flat. It sounds like someone sat on your hood and stretched the metal. I wouldnt spot weld it if thats the case. It would look better but still not good. Try to find a new hood. Picture would help.
BluFbdy
PostPosted: Fri Nov 18, 2011 1:18 am    Post subject: Reply with quote
Nick (nonsensekid) has an extra rs hood I believe that might be a better route than repairing, its not a cowl but it would work
