Heres my latest car porn
PostPosted: Tue Nov 08, 2011 7:06 pm    Post subject: Heres my latest car porn Reply with quote
Due to the jokes in the craigslist post, heres my latest work. Not as cool as ians hovercraft Laughing
For you lowered people with LCA brackets. My lca's are still not level, they sit at an upangle still, and set on lowest bracket Shocked How are yours sitting?
PostPosted: Tue Nov 08, 2011 7:34 pm    Post subject: Reply with quote
I don't understand... the lower the control arm is mounted under the axle the steeper the angle up to the car. What did I miss? Confused
PostPosted: Tue Nov 08, 2011 7:42 pm    Post subject: Reply with quote
Your LCA's should be level to the ground, or slightly lower at the axle end from my readings.
So when you lower the car, you tip the lca up higher on the axle end. To put it back to level or tipped down, you install these.
PostPosted: Tue Nov 08, 2011 8:43 pm    Post subject: Reply with quote
Mine sit wherever I want! But I agree, you want them pointing up and forward a smidge. I think you should use the next higher hole.
PostPosted: Wed Nov 09, 2011 5:12 am    Post subject: Reply with quote
http://www.thirdgen.org/techboard/suspension-chassis/235762-lower-control-arm-angle.html
I still say they need to be level. Will see truely how far off they are once I get it on the ground tonight.
PostPosted: Wed Nov 09, 2011 7:08 am    Post subject: Reply with quote
Dont forget squat. Literally. Unless youve done something tricky, your car will squat on a launch. If your bars are level with the road they will now be pointed to the ground.
PostPosted: Wed Nov 09, 2011 7:17 am    Post subject: Reply with quote
Travis, I think were talking backwards on angle.
heres best diagram I can do with keystrokes.....
body / axle before
body / axle still (not as bad)
body \ axle advised for hard launch
body - axle advised for standard use
You sometimes get what you get. My car is also low enough, that the axle side of the LCA is also slightly higher than the front. Ideally it would be a smidge lower (not much though, since you induce roll-steer with it lower). Your anti-squat numbers are effected by the height of the IC though.
Drive it, and if it feels alright, run with it.
PostPosted: Wed Nov 09, 2011 7:49 am    Post subject: Reply with quote
I've noticed that all the off the shelf LCARB's only lower to arms of a maximum of 2". I'm buying a mig welder soon and will see what I can do about making myself a set that are lower
PostPosted: Wed Nov 09, 2011 8:10 am    Post subject: Reply with quote
I agree Dewey, you get what you get. Ive been driving lowered camaros for almost 10 years w/o these. So it may feel weird now!! Oddly enough, Ive never had wheel hop either.
PostPosted: Wed Nov 09, 2011 8:17 am    Post subject: Reply with quote
No wheel hop? Maybe you need more traction.
If you lower the bracket too much do you increase the leverage the axle has on the arms? Seems as if the axle will push forward (rotating forward) when the arm gets dropped down and could possibly upset the torque arm mount. Thoughts?
PostPosted: Wed Nov 09, 2011 8:25 am    Post subject: Reply with quote
Up to lately, I would have agreed with you Travis. But these tires I have now just grip n go!!
Also, the axle will be rotating backwards, thus lifting up and way from the trans mount.... unless your worried about heavy braking power?
I do have an aftermarket tq arm which is fairly solid, and I plan to brace it more some day.
PostPosted: Wed Nov 09, 2011 9:31 am    Post subject: Reply with quote
Having proper dampening from the shocks makes a HUGE amount of difference in wheel hop. I think it has more of an effect than the LCA angle does. The anti-squat value change from the LCA angle is not all that significant. Its a tangent function of the height of the IC and lenght of the torque arm SVSA length. Even with a less than optimal A/S value, with proper spring dampening, wheel-hop shouldn't be an issue.
PostPosted: Wed Nov 09, 2011 11:25 am    Post subject: Reply with quote
Offtopic; what endlinks are those?
PostPosted: Wed Nov 09, 2011 11:31 am    Post subject: Reply with quote
Home made ones I had done atleast 5 years ago. They are made of aluminum, ES bushings, and a hand picked length bolt. I had them made to attempt to correct the geometry of the swaybar. But now they are tipped at quite an angle. I need to weld n drill front control arms. Then make custom rear brackets.
PostPosted: Wed Nov 09, 2011 7:21 pm    Post subject: Reply with quote
Got it on the ground. Looks like the axle end is slightly lower, but not by much at all.
No driving on it yet.
