driveshaft loop
91camaro_rs
PostPosted: Fri May 20, 2011 5:02 pm    Post subject: driveshaft loop Reply with quote
if i go to oreillys and order the universal drive shaft loop is there a place to bolt it on, or will i have to drill holes or should i weld it on?
i need one for racing
RK82
1982 Pontiac Trans Am
PostPosted: Fri May 20, 2011 5:12 pm    Post subject: Reply with quote
yes you will have to drill holes. I have this one http://www.summitracing.com/parts/LAK-18020/
Ew.
Those are scary and only bolt to the floor pan. Either get SFCs and build one off them, or get a torque arm with provision for one. Make sure to follow rules for your racing sanctioning body for sizing and placement.
91camaro_rs
PostPosted: Sat May 21, 2011 7:44 am    Post subject: Reply with quote
where did you have to drill holes?
arent the SFC's kinda far apart to mount a loop to?
PostPosted: Sat May 21, 2011 6:43 pm    Post subject: Reply with quote
Get one of those torque arm relocation brackets with the built in loop. Might even be a tranny mount.
PostPosted: Sun May 22, 2011 12:48 am    Post subject: Reply with quote
This.
PostPosted: Sun May 22, 2011 10:23 am    Post subject: Reply with quote
This.
A link would be nice... Rolling Eyes
PostPosted: Sun May 22, 2011 10:42 am    Post subject: Reply with quote
This one Spohn makes can mount to the stock transmission mount. Requires a new poly bushing.
http://www.spohn.net/shop/1982-1992-GM-F-Body/Chassis/Driveshaft-Loop-Bolt-In/Driveshaft-Loop-Bolt-In.html
PostPosted: Sun May 22, 2011 9:54 pm    Post subject: Reply with quote
This.
Laughing You're the one that suggested it!
91camaro_rs
PostPosted: Sun May 22, 2011 10:13 pm    Post subject: Reply with quote
where does that attach too?
PostPosted: Mon May 23, 2011 7:42 am    Post subject: Reply with quote
From the description on the site...
We supply a template to mark and drill two 7/16" holes through your stock transmission crossmember. Our loop mounts to the underside of the stock transmission crossmember. You simply place the supplied 7/16" bolts and washers through the driveshaft loop mount, through the transmission crossmember, and into the polyurethane transmission mount (required).
91camaro_rs
PostPosted: Mon May 23, 2011 10:07 am    Post subject: Reply with quote
oh right on sounds easy enough
