91camaro_rs Member
Posted: Fri May 20, 2011 5:02 pm Post subject: driveshaft loop |
if i go to oreillys and order the universal drive shaft loop is there a place to bolt it on, or will i have to drill holes or should i weld it on?
i need one for racing _________________
RK82 Member
1982 Pontiac Trans Am
Posted: Fri May 20, 2011 5:12 pm Post subject: |
Ew.
Those are scary and only bolt to the floor pan. Either get SFCs and build one off them, or get a torque arm with provision for one. Make sure to follow rules for your racing sanctioning body for sizing and placement. _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Sat May 21, 2011 7:44 am Post subject: |
where did you have to drill holes?
arent the SFC's kinda far apart to mount a loop to? _________________
Posted: Sat May 21, 2011 6:43 pm Post subject: |
Get one of those torque arm relocation brackets with the built in loop. Might even be a tranny mount. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sun May 22, 2011 12:48 am Post subject: |
| RSFreak wrote: | | Get one of those torque arm relocation brackets with the built in loop. Might even be a tranny mount. |
This. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun May 22, 2011 10:23 am Post subject: |
| Alphius wrote: | | RSFreak wrote: | | Get one of those torque arm relocation brackets with the built in loop. Might even be a tranny mount. |
This. |
A link would be nice...  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sun May 22, 2011 9:54 pm Post subject: |
| RSFreak wrote: | | Alphius wrote: | | RSFreak wrote: | | Get one of those torque arm relocation brackets with the built in loop. Might even be a tranny mount. |
This. |
A link would be nice...  |
You're the one that suggested it! _________________
91camaro_rs Member
Posted: Sun May 22, 2011 10:13 pm Post subject: |
where does that attach too? _________________
Posted: Mon May 23, 2011 7:42 am Post subject: |
| 91camaro_rs wrote: | | where does that attach too? |
From the description on the site...
| Quote: | | We supply a template to mark and drill two 7/16" holes through your stock transmission crossmember. Our loop mounts to the underside of the stock transmission crossmember. You simply place the supplied 7/16" bolts and washers through the driveshaft loop mount, through the transmission crossmember, and into the polyurethane transmission mount (required). |
91camaro_rs Member
Posted: Mon May 23, 2011 10:07 am Post subject: |
oh right on sounds easy enough _________________
