cluster fix
PostPosted: Wed Oct 06, 2010 5:28 pm    Post subject: cluster fix Reply with quote
So I am going to work on fixing my cluster finally.
Tach, the thread posted a while back on the ohms, check.
Speedo. My mph reading works. But the miles does not. I have it taken apart and I see the mph, and miles work on different motors but same circuit board. Has anyone just fixed the motor for the miles?
volts. It reads less then 13. But when I stick a meter on the battery while running, I get 13.2/13.4. Any fixes for this?
redlava
PostPosted: Fri Oct 08, 2010 7:58 pm    Post subject: Reply with quote
Do the newer speedometers have the J clips that are prone to breaking?
PostPosted: Sat Oct 09, 2010 4:34 am    Post subject: Reply with quote
Dunno what a j clip is? It appears to me that the motor bust be bad as I can spin the system fairly easy with a screw driver.
Appears all gears have all the teeth too.
redlava
PostPosted: Sat Oct 09, 2010 5:03 pm    Post subject: Reply with quote
I tried to fix mine, several years ago but I gave up. I dont remember very clearly what broke without seeing it in front of me. Here is a link that might help
http://www.thirdgen.org/techboard/faq-board/249244-trip-odometer-fix-pics.html
PostPosted: Mon Oct 11, 2010 11:42 am    Post subject: Reply with quote
thats a totally different speedo then I have Sad
