Posted: Wed Oct 06, 2010 5:28 pm Post subject: cluster fix |
So I am going to work on fixing my cluster finally.
Tach, the thread posted a while back on the ohms, check.
Speedo. My mph reading works. But the miles does not. I have it taken apart and I see the mph, and miles work on different motors but same circuit board. Has anyone just fixed the motor for the miles?
volts. It reads less then 13. But when I stick a meter on the battery while running, I get 13.2/13.4. Any fixes for this? _________________ 2008 GMC Z71
redlava Member
Posted: Fri Oct 08, 2010 7:58 pm Post subject: |
| Do the newer speedometers have the J clips that are prone to breaking? |
Posted: Sat Oct 09, 2010 4:34 am Post subject: |
Dunno what a j clip is? It appears to me that the motor bust be bad as I can spin the system fairly easy with a screw driver.
Appears all gears have all the teeth too. |
redlava Member
Posted: Mon Oct 11, 2010 11:42 am Post subject: |
thats a totally different speedo then I have  |
