91camaro_rs Member
Posted: Fri Apr 30, 2010 3:07 pm Post subject: V-belt setup |
| i cant use my serp setup, i am in need of a V-belt setup, i can trade for serp or i can just give you money |
Posted: Fri Apr 30, 2010 3:35 pm Post subject: |
What's wrong with the V-belt stuff that originally was on the 305?
Just curious. _________________ 84 Camaro Z28 - LS1/T56
91camaro_rs Member
Posted: Fri Apr 30, 2010 3:39 pm Post subject: |
sold it  |
Posted: Fri Apr 30, 2010 5:30 pm Post subject: |
What's wrong with the serp setup?
Just curious.  |
kurfbird Member
Posted: Fri Apr 30, 2010 5:57 pm Post subject: v belt |
I ahve everything except the main crank pully and the Belts. Came from a 85 camaro _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
izcain 9sec Club
Posted: Fri Apr 30, 2010 9:06 pm Post subject: |
Im pretty sure I have another crank pulley! _________________
9.17 @ 148 |
91camaro_rs Member
Posted: Fri Apr 30, 2010 10:44 pm Post subject: |
ok cool, i went up to kent and got most of a setup found it on CL, but if i need anything ill let ya know
and with the serp setup it makes the alternator and water pump spin backwards...so the alternator doesnt charge and the coolant doesnt get pumped
my heater core blew as well.... |
Posted: Fri Apr 30, 2010 11:50 pm Post subject: |
Alt can spin both ways. I had a spare h20 pump for serp setups just laying in the garage.  _________________
Posted: Sat May 01, 2010 7:59 am Post subject: |
| iansane wrote: | Alt can spin both ways. I had a spare h20 pump for serp setups just laying in the garage.  |
The alt isn't charging because it isn't being switched on by the trigger wire. There are two wires coming out of the plug on that CS130: one small and one large (ignore the largest one on the post for now).
The smaller wire goes to your voltmeter or idiot gen light. The larger wire is the regulator trigger wire, and it needs to go to wherever the fat wire from the alternator post, the fusable links that feed the fusebox, and the positive battery cable all join. This varies by car, but on yours it should be the big lug on the starter.
This wire needs to have a fusable link in it, and it needs to be a min of 14ga. |
Posted: Sat May 01, 2010 8:53 am Post subject: |
| Was going to say, alternator charges either way. But it also doesnt spin backwards with a serp setup. All pulleys with the small grooves spin the correct direction, all with the smooth face against the belt spin backwards. |
91camaro_rs Member
Posted: Sat May 01, 2010 12:49 pm Post subject: |
| aaron_sK wrote: | | iansane wrote: | Alt can spin both ways. I had a spare h20 pump for serp setups just laying in the garage.  |
you totally lost me, im confused
and also another issue with the car was when i was trying to drive it to walts to have the exhaust done, it wouldnt go, like i had it in drive and everything tried 1st and 2nd and petal was to the floor, it went for a little bit but then stopped and it wouldnt go past like 1,100 rpm (v6 tach) |
Posted: Sat May 01, 2010 2:00 pm Post subject: |
| 91camaro_rs wrote: | | and also another issue with the car was when i was trying to drive it to walts to have the exhaust done, it wouldnt go, like i had it in drive and everything tried 1st and 2nd and petal was to the floor, it went for a little bit but then stopped and it wouldnt go past like 1,100 rpm (v6 tach) |
Fix that TV cable.
| 91camaro_rs wrote: | you totally lost me, im confused |
91camaro_rs Member
Posted: Sat May 01, 2010 8:45 pm Post subject: |
| so if the wires in the harness are setup right and i plug in the alternator it should work right? so the wiring is good and possibly the alternator is bad? |
Posted: Sat May 01, 2010 8:49 pm Post subject: |
| Have Blatozone test it if you're unsure about it. |
91camaro_rs Member
Posted: Sun May 02, 2010 2:49 pm Post subject: |
| now im just thinkin about buying all new pulleys but im wont be totally sure until i can try out what i have |
Posted: Sun May 02, 2010 9:21 pm Post subject: |
Gotta stop throwing money at your problems, dude. New pulleys aren't going to make your alternator work better. |
91camaro_rs Member
Posted: Mon May 03, 2010 7:08 am Post subject: |
| haha i was just thinkin bout gettin new pulleys to make it look nice so i dont have any pulleys with too many grooves, i talked to the guy i got the alternator and serp setup from and he said its probably dead. |
91camaro_rs Member
Posted: Mon May 03, 2010 1:53 pm Post subject: |
| wow i really need to sort this crap out.... so i remember the volt guage inside working so technically the wires going to the alt should be ok, i wil have to double check and get the alt tested, but instead of completly switching to v-belt couldnt i just get a new alt (if its bad) and a reverse flow water pump? |
Posted: Mon May 03, 2010 2:08 pm Post subject: |
| Yes. Yes you can. Like $30 or something for the reverse flow? If you want ultra cheap parts just to get it together, go talk to a big red headed guy at autozone on 6th. |
91camaro_rs Member
Posted: Mon May 03, 2010 2:33 pm Post subject: |
alright cool, i think i will get a reverse flow and probably a new alternator, and the bolts im missing that hold the serp setup on haha oops
i get the car back tomorrow, hopefully i can get it drivable before the uptown show |
