		| Author | Message |
		| 91camaro_rs Member
 1991  Chevrolet  Camaro RS
				|  Posted: Fri Apr 30, 2010 3:07 pm    Post subject: V-belt setup |   |
				| i cant use my serp setup, i am in need of a V-belt setup, i can trade for serp or i can just give you money |  |
		| Back to top |  |
		| Alphius Peanut
 1984  Chevrolet  Camaro Z/28
				|  Posted: Fri Apr 30, 2010 3:35 pm    Post subject: |   |
				| What's wrong with the V-belt stuff that originally was on the 305?
 Just curious.
		| Back to top |  |
		| 91camaro_rs Member
				|  Posted: Fri Apr 30, 2010 3:39 pm    Post subject: |   |
				| sold it      |  |
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Fri Apr 30, 2010 5:30 pm    Post subject: |   |
				| What's wrong with the serp setup?
 Just curious.
		| Back to top |  |
		| kurfbird Member
				|  Posted: Fri Apr 30, 2010 5:57 pm    Post subject: v belt |   |
				| I ahve everything except the main crank pully and the Belts.  Came from a 85 camaro _________________
 kurfbird
 1991 Camaro 3.1 v6
 1991 Firebird 3.1 v6
 1992 Formula 350 5.7
 700r4 Transmissions
 brucesthirdgenparts.com
		| Back to top |  |
		| izcain 9sec Club
 1983  Chevrolet  Camaro Z/28
				|  Posted: Fri Apr 30, 2010 9:06 pm    Post subject: |   |
				| Im pretty sure I have another crank pulley! _________________
 9.17 @ 148
		| Back to top |  |
		| 91camaro_rs Member
				|  Posted: Fri Apr 30, 2010 10:44 pm    Post subject: |   |
				| ok cool, i went up to kent and got most of a setup found it on CL, but if i need anything ill let ya know
 and with the serp setup it makes the alternator and water pump spin backwards...so the alternator doesnt charge and the coolant doesnt get pumped
 my heater core blew as well....
		| Back to top |  |
		| iansane Member
 1991  Pontiac  Trans Am
				|  Posted: Fri Apr 30, 2010 11:50 pm    Post subject: |   |
				| Alt can spin both ways. I had a spare h20 pump for serp setups just laying in the garage.  _________________
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sat May 01, 2010 7:59 am    Post subject: |   |
				|  	  | iansane wrote: |  	  | Alt can spin both ways. I had a spare h20 pump for serp setups just laying in the garage.  |
 The alt isn't charging because it isn't being switched on by the trigger wire. There are two wires coming out of the plug on that CS130: one small and one large (ignore the largest one on the post for now).
 The smaller wire goes to your voltmeter or idiot gen light. The larger wire is the regulator trigger wire, and it needs to go to wherever the fat wire from the alternator post, the fusable links that feed the fusebox, and the positive battery cable all join. This varies by car, but on yours it should be the big lug on the starter.
 This wire needs to have a fusable link in it, and it needs to be a min of 14ga.
		| Back to top |  |
		| chevymad Master B
 1987  Pontiac  Formula
				|  Posted: Sat May 01, 2010 8:53 am    Post subject: |   |
				| Was going to say, alternator charges either way. But it also doesnt spin backwards with a serp setup. All pulleys with the small grooves spin the correct direction, all with the smooth face against the belt spin backwards. |  |
		| Back to top |  |
		| 91camaro_rs Member
				|  Posted: Sat May 01, 2010 12:49 pm    Post subject: |   |
				|  	  | aaron_sK wrote: |  	  |  	  | iansane wrote: |  	  | Alt can spin both ways. I had a spare h20 pump for serp setups just laying in the garage.  |
 you totally lost me, im confused
 and also another issue with the car was when i was trying to drive it to walts to have the exhaust done, it wouldnt go, like i had it in drive and everything tried 1st and 2nd and petal was to the floor, it went for a little bit but then stopped and it wouldnt go past like 1,100 rpm (v6 tach)
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sat May 01, 2010 2:00 pm    Post subject: |   |
				|  	  | 91camaro_rs wrote: |  	  | and also another issue with the car was when i was trying to drive it to walts to have the exhaust done, it wouldnt go, like i had it in drive and everything tried 1st and 2nd and petal was to the floor, it went for a little bit but then stopped and it wouldnt go past like 1,100 rpm (v6 tach) |
 Fix that TV cable.
  	  | 91camaro_rs wrote: |  	  | you totally lost me, im confused   |
		| Back to top |  |
		| 91camaro_rs Member
				|  Posted: Sat May 01, 2010 8:45 pm    Post subject: |   |
				| so if the wires in the harness are setup right and i plug in the alternator it should work right? so the wiring is good and possibly the alternator is bad? |  |
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sat May 01, 2010 8:49 pm    Post subject: |   |
				| Have Blatozone test it if you're unsure about it. |  |
		| Back to top |  |
		| 91camaro_rs Member
				|  Posted: Sun May 02, 2010 2:49 pm    Post subject: |   |
				| now im just thinkin about buying all new pulleys but im wont be totally sure until i can try out what i have |  |
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sun May 02, 2010 9:21 pm    Post subject: |   |
 Gotta stop throwing money at your problems, dude. New pulleys aren't going to make your alternator work better.
		| Back to top |  |
		| 91camaro_rs Member
				|  Posted: Mon May 03, 2010 7:08 am    Post subject: |   |
				| haha i was just thinkin bout gettin new pulleys to make it look nice so i dont have any pulleys with too many grooves, i talked to the guy i got the alternator and serp setup from and he said its probably dead. |  |
		| Back to top |  |
		| 91camaro_rs Member
				|  Posted: Mon May 03, 2010 1:53 pm    Post subject: |   |
				| wow i really need to sort this crap out.... so i remember the volt guage inside working so technically the wires going to the alt should be ok, i wil have to double check and get the alt tested, but instead of completly switching to v-belt couldnt i just get a new alt (if its bad) and a reverse flow water pump? |  |
		| Back to top |  |
		| iansane Member
				|  Posted: Mon May 03, 2010 2:08 pm    Post subject: |   |
				| Yes. Yes you can. Like $30 or something for the reverse flow? If you want ultra cheap parts just to get it together, go talk to a big red headed guy at autozone on 6th. |  |
		| Back to top |  |
		| 91camaro_rs Member
				|  Posted: Mon May 03, 2010 2:33 pm    Post subject: |   |
				| alright cool, i think i will get a reverse flow and probably a new alternator, and the bolts im missing that hold the serp setup on  haha oops
 i get the car back tomorrow, hopefully i can get it drivable before the uptown show
		| Back to top |  |
