91camaro_rs Member
Posted: Thu Apr 01, 2010 10:23 pm Post subject: TPI intake tube |
i need the accordian tube that goes from the snorkel intake to the throttle body, im using speed density so i dont need the MAF style tube (im assuming they are different) _________________
Posted: Thu Apr 01, 2010 10:33 pm Post subject: |
Do you just need the accordion piece? I have the full intake tube+accordion+K&N cone filter that you can have for cheap? _________________
91camaro_rs Member
Posted: Thu Apr 01, 2010 11:27 pm Post subject: |
Ah. The one I have is short. Meant for the firebird/SLP intake. Single sided version of this;
Posted: Fri Apr 02, 2010 6:19 am Post subject: |
Geez. That guy is way to proud of his used junk. |
flea Member
Posted: Fri Apr 02, 2010 10:03 am Post subject: |
i like how he took the picture with the IROC right above it. Gives the idea that if you spend your money on this one then you have IROC parts on your car. Now don't laugh at that too much, somewhere someone will be selling a "1990 Camaro with IROC intake" on CL.
Oh no, I just read the description, he says it came off of a 1992 car. So that means the IROC in the picture really is just a prop and not even the donor car. never trust advertising. _________________ Killing mailboxes since 2009 |
91camaro_rs Member
Posted: Fri Apr 09, 2010 2:16 pm Post subject: |
ok well i can use eithr a MAF one or a SD, i just need the acordion peice, doesnt matter which type, as long as its for TPI _________________
