TPI intake tube
91camaro_rs
PostPosted: Thu Apr 01, 2010 10:23 pm    Post subject: TPI intake tube Reply with quote
i need the accordian tube that goes from the snorkel intake to the throttle body, im using speed density so i dont need the MAF style tube (im assuming they are different)
PostPosted: Thu Apr 01, 2010 10:33 pm    Post subject: Reply with quote
Do you just need the accordion piece? I have the full intake tube+accordion+K&N cone filter that you can have for cheap?
91camaro_rs
PostPosted: Thu Apr 01, 2010 11:01 pm    Post subject: Reply with quote
I have a snorkel intake now and i still wanna use it, so im pretty sure i just need the accordion piece,
this one has a MAF, i need the longer style one, but thats the only piece i need
This is the one i need: (dont really wanna pay $50 for it tho)
http://cgi.ebay.com/ebaymotors/90-92-Camaro-Z28-TPI-RUBBER-INTAKE-BOOT-91-Iroc-Z_W0QQcmdZViewItemQQhashZitem563aea8db0QQitemZ370355637680QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
PostPosted: Thu Apr 01, 2010 11:27 pm    Post subject: Reply with quote
Ah. The one I have is short. Meant for the firebird/SLP intake. Single sided version of this;
PostPosted: Fri Apr 02, 2010 6:19 am    Post subject: Reply with quote
Geez. That guy is way to proud of his used junk.
PostPosted: Fri Apr 02, 2010 10:03 am    Post subject: Reply with quote
i like how he took the picture with the IROC right above it. Gives the idea that if you spend your money on this one then you have IROC parts on your car. Now don't laugh at that too much, somewhere someone will be selling a "1990 Camaro with IROC intake" on CL.
Oh no, I just read the description, he says it came off of a 1992 car. So that means the IROC in the picture really is just a prop and not even the donor car. never trust advertising.
Killing mailboxes since 2009
91camaro_rs
PostPosted: Fri Apr 09, 2010 2:16 pm    Post subject: Reply with quote
ok well i can use eithr a MAF one or a SD, i just need the acordion peice, doesnt matter which type, as long as its for TPI
