IROC-stangs Member
Posted: Wed Feb 24, 2010 5:01 pm Post subject: brake problem |
| hi i was wondering if you all know what i need so i can have decent brakes again. ok i have a 87 iroc-z with which i belive its called j65 package ( 4wheel disk brakes) and they barely work at all it takes for ever to slow down. do i need just new rotors/pads? my calipers and my rotors are completly rusted out and do you think new rotos and pads would help? i dont need to stop on a dime but i need it to stop good so what do you guys think i need and what brands should i chose? thanks. also the brake pedal is not hard it just is really soft feeling and you have to push ALL the way down on the pedal for the car to finally stop |
Posted: Wed Feb 24, 2010 5:21 pm Post subject: |
Had new but stock 4-wheel disks on my '87. Was never happy with it. Would have done an LS1 swap had I kept the car.
Just my two cents. |
IROC-stangs Member
Posted: Wed Feb 24, 2010 5:27 pm Post subject: |
| aaron_sK wrote: | Had new but stock 4-wheel disks on my '87. Was never happy with it. Would have done an LS1 swap had I kept the car.
dont you need the whole ls1 rear end? how much work is that to put on? how much can you get them for and i would need someone to pull it for me since the u-pull it doesnt allow anyone under 18. and what are some of the good posi gearings 3.42 seems pretty good if avaliable |
Posted: Wed Feb 24, 2010 5:35 pm Post subject: |
Rears aren't the problem. They're just along for the ride, providing maybe 20% of the braking power.
It's the master, and fronts that cause crap brakes in Chebbies. |
IROC-stangs Member
Posted: Wed Feb 24, 2010 5:38 pm Post subject: |
| aaron_sK wrote: | Rears aren't the problem. They're just along for the ride, providing maybe 20% of the braking power.
so do a ls1 front brake swap? and what is all included in that? how much would i all need to spend? |
Posted: Wed Feb 24, 2010 7:00 pm Post subject: |
LS1s are definitely going to be better but it couldn't hurt to fix up what you have now. New calipers are only like $15 a piece or something? Calipers/rotors/pads/SS braided hoses and a GOOD fluid to flush out the lines and you'd probably already be at the limit of whatever tire you're using...
Although I can perfectly understand wanting to upgrade. Any brake swap is going to require about the same work. Taking spindles, chopping off the stock mounting ears, taping the dust holes, bolt on new adapter bracket, turn stock rotors down until it's just a hub and bolt everything back together. _________________
IROC-stangs Member
Posted: Wed Feb 24, 2010 10:39 pm Post subject: |
| iansane wrote: | LS1s are definitely going to be better but it couldn't hurt to fix up what you have now. New calipers are only like $15 a piece or something? Calipers/rotors/pads/SS braided hoses and a GOOD fluid to flush out the lines and you'd probably already be at the limit of whatever tire you're using...
Although I can perfectly understand wanting to upgrade. Any brake swap is going to require about the same work. Taking spindles, chopping off the stock mounting ears, taping the dust holes, bolt on new adapter bracket, turn stock rotors down until it's just a hub and bolt everything back together. |
thanks so would you happen to know how much an ls1 kit from a junkyard would cost vs just replacing calipers, rotors, and etc.? i dont need it to be fixed right now for a few yrs when i start driving so i can save up. i just want to make sure i have strong braking power. thanks. |
Posted: Wed Feb 24, 2010 10:45 pm Post subject: |
You might do better at the junkyard, but I got my LS1 rear brakes off e-Bay for $200. Almost everything I needed, except pads. The kit comes with backing plates, rotors, calipers, flex lines and rear cables with brackets. I already had a disc rear on the car, so that made things a bit easier. _________________ 92 Camaro
IROC-stangs Member
Posted: Wed Feb 24, 2010 11:45 pm Post subject: |
| Al Hasse wrote: | | You might do better at the junkyard, but I got my LS1 rear brakes off e-Bay for $200. Almost everything I needed, except pads. The kit comes with backing plates, rotors, calipers, flex lines and rear cables with brackets. I already had a disc rear on the car, so that made things a bit easier. |
thanks and that was just the brakes and not the rear end correct? do you have to do any modifications if you dont have an ls1 rear end? im wondering if i should try to get a ls1 rear end and front brakes. |
Posted: Thu Feb 25, 2010 5:16 am Post subject: |
Just the brakes. They pretty much bolt up to the 3rd gen disc brake axle housing. Only real mod required would be to the parking brake, I took the handle, front cable and tunnel bracket from a 4th gen car to make mine work. I also had some braided lines fabricated, though some say this isn't necessary.
You can check out my swap here...
http://cascadecrew.org/phpBB2/viewtopic.php?t=5869&highlight=rear |
IROC-stangs Member
Posted: Thu Feb 25, 2010 8:28 am Post subject: |
| Al Hasse wrote: | Just the brakes. They pretty much bolt up to the 3rd gen disc brake axle housing. Only real mod required would be to the parking brake, I took the handle, front cable and tunnel bracket from a 4th gen car to make mine work. I also had some braided lines fabricated, though some say this isn't necessary.
thanks i'll check it out in a bit. how do you like the performance? and not trying to get ahead of myself but is it better to get an complete rear end with brakes from a ls1 car? or are the rear ends basically just as weak? thanks. |
IROC-stangs Member
Posted: Thu Feb 25, 2010 8:43 am Post subject: |
| IROC-stangs wrote: | | Al Hasse wrote: | Just the brakes. They pretty much bolt up to the 3rd gen disc brake axle housing. Only real mod required would be to the parking brake, I took the handle, front cable and tunnel bracket from a 4th gen car to make mine work. I also had some braided lines fabricated, though some say this isn't necessary.
i read the thread and i didnt happen to see how much you paided and how long just installing the brakes took. btw is there anyone that lives around me (tigard) that could possibly help if i do this or another thing if i get stuck? |
Posted: Thu Feb 25, 2010 11:05 am Post subject: |
Both 3rd gen and 4th Gen (read: LS1) rear's have basically the same size ring and pinion gear, its a GM 7.625. The actual axle for a 4th gen is (I think) 2" longer on each side, so your wheel's will poke out a bit if you use a 4th gen rear.
For now, if I were in your shoes, I'd just try bleeding/flushing the brakes and adding fresh fluid, and see if things improve. _________________
IROC-stangs Member
Posted: Thu Feb 25, 2010 11:29 am Post subject: |
| Quasi-Traction wrote: | | IROC-stangs wrote: |
For now, if I were in your shoes, I'd just try bleeding/flushing the brakes and adding fresh fluid, and see if things improve. |
thanks how much are bleeding kits and dont you have to have an additional person? thanks. |
alloy T56 Elitist
Posted: Thu Feb 25, 2010 1:05 pm Post subject: |
You can "rent" a vacuum brake bleeder from Schucks. You pay the full price of the kit, but when you bring it back you get all your $$$ back. It's their loan a tool program. _________________ Member of the "Elite T56 Club" , big brake club, and "burgundy" (not red or maroon) car owner.
IROC-stangs Member
Posted: Thu Feb 25, 2010 1:07 pm Post subject: |
| alloy wrote: | | You can "rent" a vacuum brake bleeder from Schucks. You pay the full price of the kit, but when you bring it back you get all your $$$ back. It's their loan a tool program. |
cool thanks what do you all have to do to bleed them? and how long does it usally take? |
alloy T56 Elitist
Posted: Thu Feb 25, 2010 1:14 pm Post subject: |
First I'd use a turkey baster and get all the old fluid out of the master cylinder, and then clean it out with a lint free cloth. The add new fluid. Check often to make sure you have not run out of fluid when bleeding. If you do you will have to start over again.
Clean off the brake bleeders and then loosen them one at a time. then attach the vacuum bleeder to the fitting and pump it. I'd get the little container of the bleeder about half full and then check the master, and then move on to the next one. Do the right rear first, then the left rear, then the right front, then the left front. You go from the furthest wheel to the shortest one from the master. _________________ Member of the "Elite T56 Club" , big brake club, and "burgundy" (not red or maroon) car owner.
IROC-stangs Member
Posted: Thu Feb 25, 2010 1:28 pm Post subject: |
| alloy wrote: | First I'd use a turkey baster and get all the old fluid out of the master cylinder, and then clean it out with a lint free cloth. The add new fluid. Check often to make sure you have not run out of fluid when bleeding. If you do you will have to start over again.
Clean off the brake bleeders and then loosen them one at a time. then attach the vacuum bleeder to the fitting and pump it. I'd get the little container of the bleeder about half full and then check the master, and then move on to the next one. Do the right rear first, then the left rear, then the right front, then the left front. You go from the furthest wheel to the shortest one from the master. |
thanks for the instructions this might sound stupid but what is the point of the bleeding? to get the old fluid out? |
IROC-stangs Member
Posted: Thu Feb 25, 2010 1:35 pm Post subject: |
| also for brakes in the future is there any other brakes that will fit that are better then ls1 f-body brakes? are c5/c6 z06 brakes better? |
alloy T56 Elitist
Posted: Thu Feb 25, 2010 2:50 pm Post subject: |
The point of bleeding is to make sure all the air is out of the system. Air is compressible, brake fluid isn't.
There are several different upgrade to the front brakes now. 1LE's, LS1's, C4/C5, The 13" wilwood kit that I designed and built, and I think john has a set of 14" fronts if I'm not mistaken. The bigger you go the more $$$ they cost.
Here is what my front setup looks like. The difference it amazing with these brakes. I drive Daisy and she kinds scares me with the stock brakes since I'm so use to my car.
