3.1 crank and pistons or 3.4 block
d00012
PostPosted: Sun May 31, 2009 6:44 pm    Post subject: 3.1 crank and pistons or 3.4 block Reply with quote
I'm in need of a 3.1 crank and pistons to stroke my 2.8. Or if someone has a 3.4 block with the pistons, crank, and cam I'll take that too. Don't have to be brand new, but can't be completly worn out.
kurfbird
PostPosted: Sun May 31, 2009 7:42 pm    Post subject: 3.1 Reply with quote
I ahve a 3.1 complete from a 1991 Camaro. Comes with everything would be a good motor for you to drop in. Asking 100.00
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
d00012
PostPosted: Sun May 31, 2009 7:54 pm    Post subject: Reply with quote
How many miles are on it? What kind of shape is it in?
kurfbird
PostPosted: Sun May 31, 2009 8:24 pm    Post subject: 3.1 miles Reply with quote
150,000 miles. Ran good. Is dirty. prior to droping it in I would repalce the rear main seal freeze plugs. And check the timing chain. And possible repalce if necessary
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
d00012
PostPosted: Mon Jun 01, 2009 7:34 am    Post subject: Reply with quote
I'll have to check it out. Not sure if I will be able to this week. Are you in a hurry to sell it?
kurfbird
PostPosted: Mon Jun 01, 2009 8:42 am    Post subject: 3.1 Reply with quote
I would like to get it sold in the next couple of weeks
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
d00012
PostPosted: Mon Jun 01, 2009 2:32 pm    Post subject: Reply with quote
I should be able to next week to come check it out. Thursday or Friday if you're available?
kurfbird
PostPosted: Mon Jun 01, 2009 4:04 pm    Post subject: 3.1 Reply with quote
I should be home after 5:00 on both days
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
d00012
PostPosted: Mon Jun 01, 2009 4:59 pm    Post subject: Reply with quote
Alright, I'll come by one of those days. Talk to my fiance and figure out which day I can go. I'll check it out and see how well it is. Smile
PM me your address?
kurfbird
PostPosted: Tue Jun 02, 2009 7:50 pm    Post subject: thur Reply with quote
Thursday or friday would work. Saturday would also be a good day.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
d00012
PostPosted: Sat Jun 06, 2009 10:15 pm    Post subject: Reply with quote
Buying an 88 Firebird. Won't be able to get the 3.1.
Someone selling it to me for $400. Doesn't run longer than 10 seconds, but should be an easy fix (if it's not the fuel pump).
Very clean engine, interior is ok, but body is very good.
