		d00012 Member
   2007  Pontiac  GTA
				 Posted: Sun May 31, 2009 6:44 pm    Post subject: 3.1 crank and pistons or 3.4 block |
				I'm in need of a 3.1 crank and pistons to stroke my 2.8. Or if someone has a 3.4 block with the pistons, crank, and cam I'll take that too. Don't have to be brand new, but can't be completly worn out. _________________
		kurfbird Member
				 Posted: Sun May 31, 2009 7:42 pm    Post subject: 3.1 |
				I ahve a 3.1 complete from a 1991 Camaro.   Comes with everything would be a good motor for you to drop in.    Asking 100.00 _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
		d00012 Member
   2007  Pontiac  GTA
				 Posted: Sun May 31, 2009 7:54 pm    Post subject:  |
				How many miles are on it? What kind of shape is it in? _________________
		kurfbird Member
				 Posted: Sun May 31, 2009 8:24 pm    Post subject: 3.1 miles |
				150,000 miles.    Ran good.   Is dirty.  prior to droping it in I would repalce the rear main seal  freeze plugs.   And check the timing chain.  And possible repalce if necessary _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
		d00012 Member
   2007  Pontiac  GTA
				 Posted: Mon Jun 01, 2009 7:34 am    Post subject:  |
				I'll have to check it out. Not sure if I will be able to this week. Are you in a hurry to sell it? _________________
		kurfbird Member
				 Posted: Mon Jun 01, 2009 8:42 am    Post subject: 3.1 |
				I would like to get it sold in the next couple of weeks _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
		d00012 Member
   2007  Pontiac  GTA
				 Posted: Mon Jun 01, 2009 2:32 pm    Post subject:  |
				I should be able to next week to come check it out. Thursday or Friday if you're available? _________________
		kurfbird Member
				 Posted: Mon Jun 01, 2009 4:04 pm    Post subject: 3.1 |
				I should be home after 5:00 on both days _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
		d00012 Member
   2007  Pontiac  GTA
				 Posted: Mon Jun 01, 2009 4:59 pm    Post subject:  |
				Alright, I'll come by one of those days. Talk to my fiance and figure out which day I can go. I'll check it out and see how well it is.
PM me your address? _________________
		kurfbird Member
				 Posted: Tue Jun 02, 2009 7:50 pm    Post subject: thur |
				Thursday or friday would work.  Saturday would also be a good day. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
		d00012 Member
   2007  Pontiac  GTA
				 Posted: Sat Jun 06, 2009 10:15 pm    Post subject:  |
				Buying an 88 Firebird. Won't be able to get the 3.1.
Someone selling it to me for $400. Doesn't run longer than 10 seconds, but should be an easy fix (if it's not the fuel pump).
Very clean engine, interior is ok, but body is very good. _________________
