Posted: Sun Apr 12, 2009 9:40 pm Post subject: 86-87 v-belt Pullies. |
Tired of the WP belt always kicking off when I launch hard.
Need crank/WP/Alternator pullies. Should be a thicker ribbed V-belt, with standard grooved V-belts behind it.
let me know if you have one + shipping to 97215. _________________
Posted: Sun Apr 12, 2009 9:46 pm Post subject: |
I have a bunch of pulley's in my garage, you are welcome to dig through them and see if I have any that you need. I am not sure what all of them came from, or if any of them will work.
--John |
Posted: Mon Apr 13, 2009 1:43 pm Post subject: |
I'm kind of interested in that Chris. I didn't know they used different v-belts in those later years. I have never had belt-hopping problems with my '81 Suburban pulleys and belts.
Do you have any pictures of what the newer stuff looks like? Just out of curiosity. _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Apr 13, 2009 3:10 pm Post subject: |
Never seen a "thick" V-belt in Chevy stuff. Just the '80 V-belt F-body stuff that has V-Belt PS and V-Belt AC and V-Belt Smog... but Serp Alt/water/crank. _________________ A redline a day keeps the carbon away! |
Posted: Mon Apr 13, 2009 9:32 pm Post subject: |
| Twilightoptics wrote: | | Never seen a "thick" V-belt in Chevy stuff. Just the '80 V-belt F-body stuff that has V-Belt PS and V-Belt AC and V-Belt Smog... but Serp Alt/water/crank. |
That strikes me as odd, as the belt setup that's on your camaro has identically what I'm looking for.
Serp? How do you figure? _________________
Posted: Mon Apr 13, 2009 9:42 pm Post subject: |
Look at the belt man... is a 5 rib Serp belt. Check it out tomorrow at band practice. _________________ A redline a day keeps the carbon away! |
Posted: Mon Apr 13, 2009 9:44 pm Post subject: |
alright.
Might take some pictures too, if you don't mind. _________________
redlava Member
Posted: Mon Apr 13, 2009 10:26 pm Post subject: |
| Make sure you look closely at the pulley set you get Chris, because I only have 4 metal grooves (5 raised sections on the belt) on my 86 alternator pulley. I know because I recently replaced it and a lot of places had a 5 metal grooved alternators (6 raised sections on the belt). I believe I ended up with one off a 86 caprice. |
