86-87 v-belt Pullies.
PostPosted: Sun Apr 12, 2009 9:40 pm    Post subject: 86-87 v-belt Pullies. Reply with quote
Tired of the WP belt always kicking off when I launch hard.
Need crank/WP/Alternator pullies. Should be a thicker ribbed V-belt, with standard grooved V-belts behind it.
let me know if you have one + shipping to 97215.
PostPosted: Sun Apr 12, 2009 9:46 pm    Post subject: Reply with quote
I have a bunch of pulley's in my garage, you are welcome to dig through them and see if I have any that you need. I am not sure what all of them came from, or if any of them will work.
--John
PostPosted: Mon Apr 13, 2009 1:43 pm    Post subject: Reply with quote
I'm kind of interested in that Chris. I didn't know they used different v-belts in those later years. I have never had belt-hopping problems with my '81 Suburban pulleys and belts.
Do you have any pictures of what the newer stuff looks like? Just out of curiosity.
PostPosted: Mon Apr 13, 2009 3:10 pm    Post subject: Reply with quote
Never seen a "thick" V-belt in Chevy stuff. Just the '80 V-belt F-body stuff that has V-Belt PS and V-Belt AC and V-Belt Smog... but Serp Alt/water/crank.
PostPosted: Mon Apr 13, 2009 9:32 pm    Post subject: Reply with quote
That strikes me as odd, as the belt setup that's on your camaro has identically what I'm looking for.
Serp? How do you figure?
PostPosted: Mon Apr 13, 2009 9:42 pm    Post subject: Reply with quote
Look at the belt man... is a 5 rib Serp belt. Check it out tomorrow at band practice.
PostPosted: Mon Apr 13, 2009 9:44 pm    Post subject: Reply with quote
alright.
Might take some pictures too, if you don't mind.
redlava
PostPosted: Mon Apr 13, 2009 10:26 pm    Post subject: Reply with quote
Make sure you look closely at the pulley set you get Chris, because I only have 4 metal grooves (5 raised sections on the belt) on my 86 alternator pulley. I know because I recently replaced it and a lot of places had a 5 metal grooved alternators (6 raised sections on the belt). I believe I ended up with one off a 86 caprice.
