jakemk8706 Member
Posted: Sun May 25, 2008 11:26 pm Post subject: gear question |
so if i were to change the gears in my car, will that eliminate my posi?
i dont really know how that works... _________________ gas brake dip dip |
Posted: Sun May 25, 2008 11:33 pm Post subject: |
If you change the whole carrier it will.
If you just change the ring and pinion, the gears will go on the carrier you have.
this is a ford Carrier, but this is basically what it looks like. _________________
Posted: Sun May 25, 2008 11:36 pm Post subject: |
It depends on what gears you currenlty have, and what gears you are switching too.
But generaly, yes you can swap gears and you will keep your posi. |
jakemk8706 Member
Posted: Mon May 26, 2008 4:17 pm Post subject: |
oh ok, just making sure..thanx _________________ gas brake dip dip |
