		jakemk8706 Member
   1991  Chevrolet  Camaro Z/28
				 Posted: Sun May 25, 2008 11:26 pm    Post subject: gear question |
				so if i were to change the gears in my car, will that eliminate my posi?
i dont really know how that works... _________________ gas brake dip dip |
				 Posted: Sun May 25, 2008 11:33 pm    Post subject:  |
				If you change the whole carrier it will.
If you just change the ring and pinion, the gears will go on the carrier you have.
this is a ford Carrier, but this is basically what it looks like. _________________
   1990  Chevrolet  Camaro RS
				 Posted: Sun May 25, 2008 11:36 pm    Post subject:  |
				It depends on what gears you currenlty have, and what gears you are switching too.
But generaly, yes you can swap gears and you will keep your posi. |
		jakemk8706 Member
				 Posted: Mon May 26, 2008 4:17 pm    Post subject:  |
				oh ok, just making sure..thanx _________________ gas brake dip dip |
