J-Dog-III Member
Posted: Mon Mar 03, 2008 4:18 pm Post subject: Need some new tires |
So i recently picked up a set of 16" iroc-z Rims off the side of the road for 100 bucks. They are Toyo Proxies FZ4's 225/50/16 in the front and 245/50/16's in the rear. I dont know if the tread depth in the fronts are ok because i dont really know how much these low profile tires usually have. But i know the rears are smoked. Looks like some one had fun and burnt the rears to nothing.
But now im looking at getting some new tires and i wanted to know if anyone had any suggestions? The tires are going on my daily driver (2.8MPFI) so no real abuse. |
STEEL Member
Posted: Mon Mar 03, 2008 5:22 pm Post subject: |
On my 79 T/a I ran 255 "road huggers" and they were alot of fun, on my 91 I have BFG radial T/a's. The BFGs get much better traction, but sometimes they flusterate me because they get too much traction in dry weather.
Road huggers = Less traction, more fun. |
Posted: Mon Mar 03, 2008 7:16 pm Post subject: |
What?!?!
I'm running mostly dead BFG Comp T/A's. No traction whatsoever. I'll trade you.  |
STEEL Member
Posted: Mon Mar 03, 2008 7:18 pm Post subject: |
| slightly under-inflated 255/60/15s Cant do a second gear burnout to save my life.... |
Posted: Mon Mar 03, 2008 7:19 pm Post subject: |
You need to shift with flair. _________________
305 302eater Member
Posted: Mon Mar 03, 2008 7:23 pm Post subject: |
 _________________ Thirdgenless |
STEEL Member
Posted: Mon Mar 03, 2008 7:24 pm Post subject: |
| iansane wrote: | | You need to shift with flair. | I can start the burn in first and get into second, but I cant rev up to 5k and dump the clutch in second. |
Hmm... that must explain my consistant sliding on 1-2 and 2-3 shifts.  |
brandyland Member
Joined: 21 Feb 2008 Posts: 343 Location: Brandyland, WA
Posted: Mon Mar 03, 2008 7:28 pm Post subject: |
I hate tires.  _________________ Picture of 'Scort goes here |
Posted: Mon Mar 03, 2008 7:34 pm Post subject: |
| STEEL wrote: | | I can start the burn in first and get into second, but I cant rev up to 5k and dump the clutch in second. |
...Why would you start in second gear? Do that some more and you're going to destroy the trans or rearend. Those are glass in our cars. |
STEEL Member
Posted: Mon Mar 03, 2008 7:36 pm Post subject: |
| My trans and my clutch are both shot, that 5k first second shift is a killer..... |
