Urgent!!!!!
PostPosted: Thu Jan 24, 2008 5:22 pm    Post subject: Urgent!!!!! Reply with quote
were is the rotor suppost to point when the crank is at top dead center?
'88 FORMULA
PostPosted: Thu Jan 24, 2008 5:24 pm    Post subject: Reply with quote
At the terminal with #1 plug wire on it.
You need to make sure that it is on the intake stroke, and not the exaust stroke also. STOCK, they say #1 is at 4 o'clock, but you just need to make sure that at TDC on the intake stroke, whereever the rotor points, is #1.
PostPosted: Thu Jan 24, 2008 5:25 pm    Post subject: Reply with quote
thank you!!
'88 FORMULA
PostPosted: Thu Jan 24, 2008 5:52 pm    Post subject: Reply with quote
When the crank is at TDC of the FIRING stroke.
Remeber, it hits TDC twice, but only fires once. Cool
PostPosted: Thu Jan 24, 2008 9:38 pm    Post subject: Reply with quote
the distributor swap is done! i didnt really get a chance to tell you guys thats what i was doing...
for some reason i just decided to pull it out by myself around 4:00, and with a few tests trial & error i got it right! Mr. Green runs perfect without any pinging like with the old distributor!
'88 FORMULA
PostPosted: Thu Jan 24, 2008 9:39 pm    Post subject: Reply with quote
Awesome! So you are on for the dyno yes?
PostPosted: Thu Jan 24, 2008 9:45 pm    Post subject: Reply with quote
oh yeah! count on it
'88 FORMULA
PostPosted: Thu Jan 24, 2008 10:00 pm    Post subject: Reply with quote
Thumbs up
Burnout
PostPosted: Thu Jan 24, 2008 10:56 pm    Post subject: Reply with quote
Very nice.
might do a doublecheck of the timing to make sure everything is running tip-top.
PostPosted: Thu Jan 24, 2008 11:05 pm    Post subject: Reply with quote
So the timing chain never solved the jumping timing I take it? good to hear you finally fixed it though.
