fiveoformula Member
Posted: Thu Jan 24, 2008 5:22 pm Post subject: Urgent!!!!! |
were is the rotor suppost to point when the crank is at top dead center? _________________
'88 FORMULA |
Posted: Thu Jan 24, 2008 5:24 pm Post subject: |
At the terminal with #1 plug wire on it.
You need to make sure that it is on the intake stroke, and not the exaust stroke also. STOCK, they say #1 is at 4 o'clock, but you just need to make sure that at TDC on the intake stroke, whereever the rotor points, is #1. |
fiveoformula Member
Posted: Thu Jan 24, 2008 5:25 pm Post subject: |
thank you!! _________________
'88 FORMULA |
Posted: Thu Jan 24, 2008 5:52 pm Post subject: |
When the crank is at TDC of the FIRING stroke.
Remeber, it hits TDC twice, but only fires once.  |
fiveoformula Member
Posted: Thu Jan 24, 2008 9:38 pm Post subject: |
the distributor swap is done! i didnt really get a chance to tell you guys thats what i was doing...
for some reason i just decided to pull it out by myself around 4:00, and with a few tests trial & error i got it right! runs perfect without any pinging like with the old distributor! _________________
'88 FORMULA |
Posted: Thu Jan 24, 2008 9:39 pm Post subject: |
Awesome! So you are on for the dyno yes?
fiveoformula Member
Posted: Thu Jan 24, 2008 9:45 pm Post subject: |
oh yeah! count on it _________________
'88 FORMULA |
Posted: Thu Jan 24, 2008 10:00 pm Post subject: |
Posted: Thu Jan 24, 2008 10:56 pm Post subject: |
| fiveoformula wrote: | the distributor swap is done! i didnt really get a chance to tell you guys thats what i was doing...
for some reason i just decided to pull it out by myself around 4:00, and with a few tests trial & error i got it right! runs perfect without any pinging like with the old distributor! |
Very nice.
might do a doublecheck of the timing to make sure everything is running tip-top. _________________
Posted: Thu Jan 24, 2008 11:05 pm Post subject: |
So the timing chain never solved the jumping timing I take it? good to hear you finally fixed it though. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
