Posted: Wed Oct 31, 2007 7:57 am Post subject: My car tried to scare me on halloween! |
Driving across the Marcom bridge this morning, my car just shut off, it wouldn't start, acted like the fuel pump wasn't running (i was on the side of the freeway I couldn't hear it), popped the hood, check electical connections, and vacuum lines, nothing i could see. I let it sit for about 5 minutes, and then it cranked right up. It was weird.
--John _________________
kenf729 Member
Joined: 22 Mar 2007 Posts: 88 Location: Forest Grove, Oregon
Posted: Wed Oct 31, 2007 8:23 am Post subject: |
John, almost sounds like your coil is going out? ...or perhaps with the frost this morning, when it melted the water shorted something out...just tossing out some ideas...
Ken _________________
Posted: Wed Oct 31, 2007 9:31 am Post subject: |
| I sat through 35 minutes of traffic before it had a problem. I wonder if VATS or something didn't freak out. I could check the coil, I think I have a spare sitting around. I have a MSD Blaster coil in there right now. |
kenf729 Member
Posted: Wed Oct 31, 2007 9:41 am Post subject: |
35 mins would have been a long enough time for the coil to get warm enough, but it would seem to me that 5 mins of cool down time wouldn't be enough, would need about 30 mins for a coil to cool down to operate again...vats or a short, when you checked for loose conections perhaps you moved a wire that was shorted out???? check the connections going into the Dist. make sure they are in good... _________________
Posted: Wed Oct 31, 2007 10:08 am Post subject: |
| What is funny, is those are the wires I didn't really mess with. I check the temp sensors, alternator, and Map sensor, I also checked the vacuum line to the MAP. It was wierd, I wish I had my laptop with me, so I could see what all the sensor readings were. |
kenf729 Member
Posted: Wed Oct 31, 2007 2:36 pm Post subject: |
John, you said you messed with the alt wires...what about the 12v+ wire comming off the alt, if that lost connection the car would just die...might take a look at that one for good clean connections.... _________________
Posted: Wed Oct 31, 2007 2:40 pm Post subject: |
I didn't really do anyting to the 12v wire, since it is on the back, I just shook the pigtail connector, since it is right out there. With no scan tool, I really didn't know what to do other than shake it. lol
"That is what my Dad taught me. Just Shake it. Cars, Shopping, and Women" -- Steven Schultz.
kenf729 Member
Posted: Wed Oct 31, 2007 3:04 pm Post subject: |
Well...you know what folks say....If you shake it more than once...you're playin with it....
Posted: Wed Oct 31, 2007 3:42 pm Post subject: |
Posted: Wed Oct 31, 2007 4:26 pm Post subject: |
I think I was misquoted.
