Posted: Fri Jul 13, 2007 2:22 pm Post subject: 145mph IROC gauge cluster |
Came out of my 1987 IROC-Z. It has the IROC-style 145mph speedo with trip reset. It is a cable driven speedo, and I have a cable for it if you need one. The trip odometer clips are broken, but I fixed it with the rewire method from TGO, so it works fine now.
The car was an L98, so it has the higher 5K/5500 redline on the tach. It was an automatic, so it doesn't have a shift light. All other lights work fine.
I can guarantee that all the gauges are working, except for the water temp. When I bought the car the water temp sender had been snapped off by a previous owner, and had been replaced with a cheapo Baxter's unit. I assume the gauge works, since the sender was the problem, but I cannot say for sure.
Odo reads 83K. Bezel is included. $60 + shipping.
Posted: Fri Jul 13, 2007 3:34 pm Post subject: |
would you do $50, and Pull the Temp gauge? _________________
Posted: Fri Jul 13, 2007 4:07 pm Post subject: |
Wow. Sorry Chris, but BigDaddyVu had dibs on it via PM by 13 minutes (on Friday the 13th no less). Sorry man.
If he doesn't want it, it's yours though. |
