145mph IROC gauge cluster
PostPosted: Fri Jul 13, 2007 2:22 pm    Post subject: 145mph IROC gauge cluster Reply with quote
Came out of my 1987 IROC-Z. It has the IROC-style 145mph speedo with trip reset. It is a cable driven speedo, and I have a cable for it if you need one. The trip odometer clips are broken, but I fixed it with the rewire method from TGO, so it works fine now.
The car was an L98, so it has the higher 5K/5500 redline on the tach. It was an automatic, so it doesn't have a shift light. All other lights work fine.
I can guarantee that all the gauges are working, except for the water temp. When I bought the car the water temp sender had been snapped off by a previous owner, and had been replaced with a cheapo Baxter's unit. I assume the gauge works, since the sender was the problem, but I cannot say for sure.
Odo reads 83K. Bezel is included. $60 + shipping.
PostPosted: Fri Jul 13, 2007 3:34 pm    Post subject: Reply with quote
would you do $50, and Pull the Temp gauge?
PostPosted: Fri Jul 13, 2007 4:07 pm    Post subject: Reply with quote
Wow. Sorry Chris, but BigDaddyVu had dibs on it via PM by 13 minutes (on Friday the 13th no less). Sorry man.
If he doesn't want it, it's yours though.
