My stick pulls out when i'm riding hard.
PostPosted: Sun Mar 25, 2007 7:59 pm    Post subject: My stick pulls out when i'm riding hard. Reply with quote
my dip stick comes out when running hard. I believe it crank case pressure it a bit high. I have a breather element on one side and a stock pvc on the other. i notice its stuck there due to the vacuum of the intake. on my other car the pvc is clicking allowing gases to be recirculated. what could i do?
Sellmanb
PostPosted: Mon Mar 26, 2007 7:19 am    Post subject: Reply with quote
If the PCV is sticking it'll cause some excess crankcase pressures. Most of the time, even w/ a sticking/stuck PCV there isnt enough pressure in the crankcase to shoot out the dipstick.
If you take the breather off the valve cover and run the motor, do you see a fair bit of gasses/smoke?
NHRA427
PostPosted: Mon Mar 26, 2007 4:21 pm    Post subject: Reply with quote
Its crank case pressure for sure. We had that problem on a drag car at the end of the run the stick was popped out and a little oil would come out. On that car we ran the breathers through the headers and no more problem. Does sound like something is clogged up some where.
PostPosted: Mon Mar 26, 2007 7:32 pm    Post subject: Reply with quote
PostPosted: Mon Mar 26, 2007 7:38 pm    Post subject: Reply with quote
ok i actually found the problem i examine my breather element carefully unlike before it is plugged up.
PostPosted: Tue Mar 27, 2007 1:51 pm    Post subject: Reply with quote
Well... that's a relief. I thought it was a lot worse after reading the title.
PostPosted: Tue Mar 27, 2007 2:32 pm    Post subject: Reply with quote
I have no problems with my gravy cannon
pathology knight
PostPosted: Tue Mar 27, 2007 2:40 pm    Post subject: Reply with quote
is there anything some "grey tape" can't do? Wink
i'm glad it was nothing to serious. Very Happy
we all gotta start somewhere....
izcain
9sec Club
PostPosted: Wed Mar 28, 2007 7:13 am    Post subject: Reply with quote
I have the same problem myself but I have not fixed it yet although I know what I need to do. Maybe next month I will fix it. I plan on getting to recovery tanks and hardlining them from the valve covers to vent the gases. Anytime I really start to lean on her she spits the dipstick out.
9.17 @ 148
