wanarunhard Member
Joined: 11 May 2006 Posts: 125 Location: ellensburg wa
Posted: Thu Nov 30, 2006 5:59 pm Post subject: world class versus non world class t5 |
| can any one explain to me the difference between trannys i mean is it a strength issue? |
Posted: Thu Nov 30, 2006 6:53 pm Post subject: |
There has been much debate about this on TGO. The general consensus seems to be that WC doesn't mean sh!t.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
turbo_jimi Member
Posted: Thu Nov 30, 2006 7:31 pm Post subject: |
i concur, it's just a name
tj _________________
Posted: Thu Nov 30, 2006 8:47 pm Post subject: |
World class = can stand up to 700 ft lbs + = bullet proof = invincible
: yawn :
/ingore post
alloy T56 Elitist
Posted: Thu Nov 30, 2006 9:03 pm Post subject: |
| Well there is one advantage to a WC verses a NWC. My car has an NWC and I lost the front cluster bearing. On an NWC the cluster bearings ride directly on the cluster, and when you lose a bearing it wipes out the bearing surface on the cluster gear. On a WC they use tapered bearings that press onto the cluster and a replaceable race in the trans case. If I were going to have to buy one, I'd go for thw WC because of this reason. I'd spend a few more $$$ on WC, but not much. Other than this one thing, I can't really see any other advantages to a WC over a NWC. |
izcain 9sec Club
Posted: Thu Nov 30, 2006 9:38 pm Post subject: |
Time for T-56 haha _________________
9.17 @ 148 |
Posted: Thu Nov 30, 2006 11:26 pm Post subject: |
| izcain wrote: | | Time for T-56 haha |
