Cheap 89 IROC-Z in Oregon
Magman
1990 Chevrolet Camaro IROC-Z
PostPosted: Tue Sep 05, 2006 12:04 am    Post subject: Cheap 89 IROC-Z in Oregon Reply with quote
One of you guys in the Portland area needs to go check this out: 89 IROC for $800. Sounds like a simple fix. If I was closer I might just own three IROC's tomorrow!
http://portland.craigslist.org/clc/car/201857927.html
I want the rear axle and rims. Well, if it's posi and if the rims are nice.
Magman
1990 IROC-Z, 383 HSR, 3.70 9-Bolt
383 RWHP / 372 TQ
11.78 @ 115 w/1.59 60' (8-18-2012)
Magman
PostPosted: Tue Sep 05, 2006 12:17 am    Post subject: Reply with quote
Here's the reply I got when I e-mailed.
Tim,
We are selling the iroc for a friend of ours. She has babied the iroc the whole time she has owned it. She had the shop replaced the rear (FACTORY) because it went out. She told me it would not start one morning. It does nothing, no clicking on the starter, it might be a ignition problem. I have the starter out and had it benched tested and it is ok. it could be the pellet on the key went bad. I don't know.the car has 140,000 miles, does not leak oil, inside is in good shape and minor scratches on the outside. If you want more info, stop by, check out the car for yourself.
(503)266-2264
383 RWHP / 372 TQ
PostPosted: Tue Sep 05, 2006 12:31 am    Post subject: Reply with quote
meh... double vein irocs. ugly.
sounds like a good deal though.
hey chris, want an iroc? it's broken... Wink
PostPosted: Tue Sep 05, 2006 5:49 am    Post subject: Reply with quote
If you happen to have an off-cap coil laying around, you could probably drive that thing home. I'd bet that's what it is, assuming the security light isn't on.
PostPosted: Tue Sep 05, 2006 8:02 am    Post subject: Reply with quote
Evil or Very Mad nah..........my camaro buying days are over....I have to make good with what the good lord gave me....
PostPosted: Tue Sep 05, 2006 10:35 am    Post subject: Reply with quote
it does not crank. starter has been bench tested.
dollars to dimes it's a vats issue or starter relay.
Magman
PostPosted: Tue Sep 05, 2006 11:32 am    Post subject: Reply with quote
Yeah, if I was to go get it I'd take a coil, ign module and a laptop/autoprom to disable VATs. Should run after that.
No one going to get this? I bet it could be had for $600 EZ Wink
383 RWHP / 372 TQ
PostPosted: Tue Sep 05, 2006 3:50 pm    Post subject: Reply with quote
When my coil was screwing up on me I had the same symptoms as a bad VATS: All dashlights on, no crank, starter was good.
Hell, I'd take it if it wasn't so far away.
Kage87Z
1969 Chevrolet Camaro
PostPosted: Tue Sep 05, 2006 10:00 pm    Post subject: Reply with quote
HHhmmmm.... must be why I have a car trailer.
Todd Beamer - 9/11
Never Forget
