Magman 11sec Club
Joined: 02 Apr 2005 Posts: 217 Location: Whidbey Island
1990 Chevrolet Camaro IROC-Z
Posted: Tue Sep 05, 2006 12:04 am Post subject: Cheap 89 IROC-Z in Oregon |
One of you guys in the Portland area needs to go check this out: 89 IROC for $800. Sounds like a simple fix. If I was closer I might just own three IROC's tomorrow!
http://portland.craigslist.org/clc/car/201857927.html
I want the rear axle and rims. Well, if it's posi and if the rims are nice.
Magman _________________ 1990 IROC-Z, 383 HSR, 3.70 9-Bolt
383 RWHP / 372 TQ
11.78 @ 115 w/1.59 60' (8-18-2012) |
Magman 11sec Club
Posted: Tue Sep 05, 2006 12:17 am Post subject: |
Here's the reply I got when I e-mailed.
Tim,
We are selling the iroc for a friend of ours. She has babied the iroc the whole time she has owned it. She had the shop replaced the rear (FACTORY) because it went out. She told me it would not start one morning. It does nothing, no clicking on the starter, it might be a ignition problem. I have the starter out and had it benched tested and it is ok. it could be the pellet on the key went bad. I don't know.the car has 140,000 miles, does not leak oil, inside is in good shape and minor scratches on the outside. If you want more info, stop by, check out the car for yourself.
(503)266-2264 _________________ 1990 IROC-Z, 383 HSR, 3.70 9-Bolt
383 RWHP / 372 TQ
Posted: Tue Sep 05, 2006 12:31 am Post subject: |
meh... double vein irocs. ugly.
sounds like a good deal though.
hey chris, want an iroc? it's broken...  |
Posted: Tue Sep 05, 2006 5:49 am Post subject: |
| If you happen to have an off-cap coil laying around, you could probably drive that thing home. I'd bet that's what it is, assuming the security light isn't on. |
Posted: Tue Sep 05, 2006 8:02 am Post subject: |
| Xophertony wrote: | meh... double vein irocs. ugly.
nah..........my camaro buying days are over....I have to make good with what the good lord gave me.... _________________
Posted: Tue Sep 05, 2006 10:35 am Post subject: |
| Asdfga3 wrote: | | If you happen to have an off-cap coil laying around, you could probably drive that thing home. I'd bet that's what it is, assuming the security light isn't on. |
it does not crank. starter has been bench tested.
dollars to dimes it's a vats issue or starter relay. |
Magman 11sec Club
Posted: Tue Sep 05, 2006 11:32 am Post subject: |
Yeah, if I was to go get it I'd take a coil, ign module and a laptop/autoprom to disable VATs. Should run after that.
No one going to get this? I bet it could be had for $600 EZ  _________________ 1990 IROC-Z, 383 HSR, 3.70 9-Bolt
383 RWHP / 372 TQ
Posted: Tue Sep 05, 2006 3:50 pm Post subject: |
When my coil was screwing up on me I had the same symptoms as a bad VATS: All dashlights on, no crank, starter was good.
Hell, I'd take it if it wasn't so far away. |
Kage87Z Member
1969 Chevrolet Camaro
