Posted: Tue Aug 29, 2006 2:19 pm Post subject: mmmm, beefier |
Can't believe the strength differance between 26 and 28 spline axles. Even Paul couldn't break these bad boys.
Posted: Tue Aug 29, 2006 2:21 pm Post subject: |
Are those Moser?
pff, paul doesn't need ot break axles, he can also break pinion gears! |
Posted: Tue Aug 29, 2006 2:22 pm Post subject: |
Heh yeah no shizzle.
You'll break something Rod. If you don't, we just know I have more power.  |
Posted: Tue Aug 29, 2006 2:52 pm Post subject: |
Yeah their Moser's.
Paul, did you have a solid pinion spacer in the rear end when the pinion broke? |
Posted: Tue Aug 29, 2006 7:00 pm Post subject: |
| rjmcgee wrote: | Yeah their Moser's.
yup! And the Differential support girdle with bearing preloads. |
Posted: Tue Aug 29, 2006 7:10 pm Post subject: |
HEHHE! I knew the 28 spline carrier wasnt going to be a problem for long!  |
Posted: Tue Aug 29, 2006 9:14 pm Post subject: |
| Twilightoptics wrote: | | rjmcgee wrote: | Yeah their Moser's.
what does the girdle with bearing preloads really do? |
Posted: Tue Aug 29, 2006 10:23 pm Post subject: |
| The girdle keeps the carrier from pushing out the back, causing the clearance in the gears to increase. It's supposed to help you keep from breaking gears. |
Posted: Wed Aug 30, 2006 7:53 am Post subject: |
| chevymad wrote: | | The girdle keeps the carrier from pushing out the back, causing the clearance in the gears to increase. It's supposed to help you keep from breaking gears. |
