mmmm, beefier
PostPosted: Tue Aug 29, 2006 2:19 pm    Post subject: mmmm, beefier Reply with quote
Can't believe the strength differance between 26 and 28 spline axles. Even Paul couldn't break these bad boys. Very Happy
PostPosted: Tue Aug 29, 2006 2:21 pm    Post subject: Reply with quote
Are those Moser?
pff, paul doesn't need ot break axles, he can also break pinion gears!
PostPosted: Tue Aug 29, 2006 2:22 pm    Post subject: Reply with quote
Heh yeah no shizzle.
You'll break something Rod. If you don't, we just know I have more power. Cool
PostPosted: Tue Aug 29, 2006 2:52 pm    Post subject: Reply with quote
Yeah their Moser's.
Paul, did you have a solid pinion spacer in the rear end when the pinion broke?
PostPosted: Tue Aug 29, 2006 7:00 pm    Post subject: Reply with quote
rjmcgee wrote:
Yeah their Moser's.
yup! And the Differential support girdle with bearing preloads.
PostPosted: Tue Aug 29, 2006 7:10 pm    Post subject: Reply with quote
HEHHE! I knew the 28 spline carrier wasnt going to be a problem for long! Wink
PostPosted: Tue Aug 29, 2006 9:14 pm    Post subject: Reply with quote
rjmcgee wrote:
Yeah their Moser's.
what does the girdle with bearing preloads really do?
PostPosted: Tue Aug 29, 2006 10:23 pm    Post subject: Reply with quote
The girdle keeps the carrier from pushing out the back, causing the clearance in the gears to increase. It's supposed to help you keep from breaking gears.
PostPosted: Wed Aug 30, 2006 7:53 am    Post subject: Reply with quote
Embarassed
