sbc 400 in 87 iroc
PostPosted: Mon Jul 10, 2006 9:37 pm    Post subject: sbc 400 in 87 iroc Reply with quote
Can a stock tpi fit on a 400 sbc . A customer of mine gave me a sbc 400 for free and was curious if the brackets and computer sensors will bolt up to the 400 sbc. i was thinking about installing it (after rebuilt) in my 87 tpi iroc. Don't worry about the ecm bs i got the stuff to do it. It looked like i need to use the heads from the 88 5.7l but that would built too much compression right? is it practicle? i like to retain the tpi if possible.
PostPosted: Mon Jul 10, 2006 9:44 pm    Post subject: Reply with quote
Your power will prolly peak under 4000 rpm. TPI kinda sucks for performance on the smaller small blocks, much less a 400. I think it will all bolt together though, the stock head choices suck since they are smogger heads. Might be able to use a bigger dished piston and the L98 heads though.
PostPosted: Mon Jul 10, 2006 10:25 pm    Post subject: Reply with quote
http://www.thirdgen.org/techboard/engine-swap/308176-400sbc-tpi-project-need.html
http://www.thirdgen.org/techboard/engine-swap/55728-some-observations-about-older.html
It's been done before. You'll probably need bigger injectors though, and some porting. The larger the displacement, the more of a bottleneck that intake will become. Depends on how much you want that sleeper look.
PostPosted: Tue Jul 11, 2006 12:26 pm    Post subject: Reply with quote
Depends on the intake TPI you have. You might have to drill out the intake center 4 bolts to fit the newer/older style heads. And the knock sensor is different. You WILL need different injectors and most likely a program.
z28redline
PostPosted: Wed Jul 12, 2006 6:23 pm    Post subject: Reply with quote
If you want to build a 400ci and get some power talk to Cheezx on this board. He did it with TPI and the motor he built is really quite impressive.
z28redline
View user's profile Send private message Visit poster's website MSN Messenger
