BigDaddyVu 12sec Club
Posted: Mon Jul 10, 2006 9:37 pm Post subject: sbc 400 in 87 iroc |
Can a stock tpi fit on a 400 sbc . A customer of mine gave me a sbc 400 for free and was curious if the brackets and computer sensors will bolt up to the 400 sbc. i was thinking about installing it (after rebuilt) in my 87 tpi iroc. Don't worry about the ecm bs i got the stuff to do it. It looked like i need to use the heads from the 88 5.7l but that would built too much compression right? is it practicle? i like to retain the tpi if possible. _________________
Posted: Mon Jul 10, 2006 9:44 pm Post subject: |
| Your power will prolly peak under 4000 rpm. TPI kinda sucks for performance on the smaller small blocks, much less a 400. I think it will all bolt together though, the stock head choices suck since they are smogger heads. Might be able to use a bigger dished piston and the L98 heads though. |
Posted: Tue Jul 11, 2006 12:26 pm Post subject: |
| Depends on the intake TPI you have. You might have to drill out the intake center 4 bolts to fit the newer/older style heads. And the knock sensor is different. You WILL need different injectors and most likely a program. |
z28redline Member
Joined: 21 Jan 2004 Posts: 83 Location: Vancouver, B.C
Posted: Wed Jul 12, 2006 6:23 pm Post subject: |
If you want to build a 400ci and get some power talk to Cheezx on this board. He did it with TPI and the motor he built is really quite impressive.
z28redline |
