Posted: Fri May 12, 2006 5:53 pm Post subject: Check your following distance? What does it look like under? |
Those of you that have followed me... well that would be everyone (tony)
Should notice the improvement.
Bored + Broke = Fixation |
Posted: Fri May 12, 2006 9:46 pm Post subject: |
| Umm. what'd you do? Don't think i've ever seen that before?! |
Posted: Fri May 12, 2006 11:32 pm Post subject: |
I raised the exhaust. Here is a preliminary before. After a while the exhaust hung real low at the rear end and then some. And also under the passenger door. I was bored and poor so I cut it all off and ... knowing how to weld and the movement of metal.... redid it.
Here is a before shot. Which isn't hanging as low as it was when Tony saw it two weeks ago.
Posted: Sat May 13, 2006 12:00 am Post subject: |
it looked like he had a differential that was mounted on the side. it hung lower then anything else.........
looks good paul. |
Posted: Sat May 13, 2006 11:03 am Post subject: |
Looks good paul!
Did your car come with that red Z/28 emblem on the bumper? I'm trying to find red ones for the GFX and bumper for my 85. _________________
Posted: Sat May 13, 2006 1:24 pm Post subject: |
| Quasi-Traction wrote: | | Did your car come with that red Z/28 emblem on the bumper? I'm trying to find red ones for the GFX and bumper for my 85. |
I found some decals I'm considering using since I don't have one with the bowtie on the back. Can be used in place of or over top of factory emblems. Scroll down about 1/3.
http://www.autografics.com/pages/camos3.htm
I'm considering the set at the bottom of the page in reflective white (will pass as light silver) even though I may not use the crossed flags or all 4 of the small bowties. |
Posted: Sat May 13, 2006 5:46 pm Post subject: |
Al,
I found the Red Z/28 emblems I"m looking for. Are those just stickers for the factory plastic piece that pegs/glues to the GFX and bumper or are they full on plastic decals? _________________
Posted: Sat May 13, 2006 7:14 pm Post subject: |
| Those are vinyl stickers, that's how they can be used on top of the original. |
Posted: Sun May 14, 2006 7:23 am Post subject: |
| I painted the strip and the emblem with the same paint I used on the turnsignals... then covered it with duplicolor clear coat. |
Posted: Sun May 14, 2006 8:51 pm Post subject: |
That looks great Paul, but I have never seen that end of your car before.  |
Posted: Sun May 14, 2006 9:17 pm Post subject: |
Posted: Mon May 15, 2006 9:36 am Post subject: |
| rjmcgee wrote: | That looks great Paul, but I have never seen that end of your car before.  |
