Check your following distance? What does it look like under?
PostPosted: Fri May 12, 2006 5:53 pm    Post subject: Check your following distance? What does it look like under? Reply with quote
Those of you that have followed me... well that would be everyone Twisted Evil Razz (tony)
Should notice the improvement.
Bored + Broke = Fixation
PostPosted: Fri May 12, 2006 9:46 pm    Post subject: Reply with quote
Umm. what'd you do? Don't think i've ever seen that before?!
PostPosted: Fri May 12, 2006 11:32 pm    Post subject: Reply with quote
I raised the exhaust. Here is a preliminary before. After a while the exhaust hung real low at the rear end and then some. And also under the passenger door. I was bored and poor so I cut it all off and ... knowing how to weld and the movement of metal.... redid it.
Here is a before shot. Which isn't hanging as low as it was when Tony saw it two weeks ago.
PostPosted: Sat May 13, 2006 12:00 am    Post subject: Reply with quote
it looked like he had a differential that was mounted on the side. it hung lower then anything else.........
looks good paul.
PostPosted: Sat May 13, 2006 11:03 am    Post subject: Reply with quote
Looks good paul!
Did your car come with that red Z/28 emblem on the bumper? I'm trying to find red ones for the GFX and bumper for my 85.
PostPosted: Sat May 13, 2006 1:24 pm    Post subject: Reply with quote
I found some decals I'm considering using since I don't have one with the bowtie on the back. Can be used in place of or over top of factory emblems. Scroll down about 1/3.
http://www.autografics.com/pages/camos3.htm
I'm considering the set at the bottom of the page in reflective white (will pass as light silver) even though I may not use the crossed flags or all 4 of the small bowties.
PostPosted: Sat May 13, 2006 5:46 pm    Post subject: Reply with quote
Al,
I found the Red Z/28 emblems I"m looking for. Are those just stickers for the factory plastic piece that pegs/glues to the GFX and bumper or are they full on plastic decals?
PostPosted: Sat May 13, 2006 7:14 pm    Post subject: Reply with quote
Those are vinyl stickers, that's how they can be used on top of the original.
PostPosted: Sun May 14, 2006 7:23 am    Post subject: Reply with quote
I painted the strip and the emblem with the same paint I used on the turnsignals... then covered it with duplicolor clear coat.
PostPosted: Sun May 14, 2006 8:51 pm    Post subject: Reply with quote
That looks great Paul, but I have never seen that end of your car before. Razz
PostPosted: Sun May 14, 2006 9:17 pm    Post subject: Reply with quote
Ha ha Laughing so hard it hurts
PostPosted: Mon May 15, 2006 9:36 am    Post subject: Reply with quote
BS!
