rice B-4 Member
Posted: Wed Feb 01, 2006 7:49 pm Post subject: Stealth ram limit |
How much power can a steath ram handle e.i. a twin turbo set up? _________________ "Horse power is how fast you hit the wall, Torque is how far you take the wall with you."
99 Camaro Z28 LS1 |
Posted: Wed Feb 01, 2006 8:07 pm Post subject: |
with twin turbo's. Enough that I know, you would kill yourself before the peddle found the floor.  |
Posted: Wed Feb 01, 2006 8:32 pm Post subject: |
I'm going to agree with john on this one and say when it comes to forced induction it's more a matter of how big your snails are.  |
rice B-4 Member
Posted: Wed Feb 01, 2006 9:08 pm Post subject: |
Dose that mean that you don't know?  _________________ "Horse power is how fast you hit the wall, Torque is how far you take the wall with you."
99 Camaro Z28 LS1 |
Sellmanb Member
Posted: Wed Feb 01, 2006 9:14 pm Post subject: |
I think they're trying to say that with forced induction, the last thing you would have to worry about is the intake  |
Posted: Wed Feb 01, 2006 9:51 pm Post subject: |
| Sellmanb wrote: | I think they're trying to say that with forced induction, the last thing you would have to worry about is the intake  |
I'm going to agree with Bobby.
Twin Turbos require a car AND $$ |
Posted: Wed Feb 01, 2006 10:04 pm Post subject: |
| Twilightoptics wrote: | | Twin Turbos require a car AND $$ |
I'm going to rephrase this properly.
TIME and $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$. |
Posted: Wed Feb 01, 2006 10:08 pm Post subject: |
936.4 HP (flywheel of course)
rice B-4 Member
Posted: Thu Feb 02, 2006 5:35 pm Post subject: |
OK, if one were going to run twin turbos on a small block what type of fuel dilevery system would you guys recomend. _________________ "Horse power is how fast you hit the wall, Torque is how far you take the wall with you."
99 Camaro Z28 LS1 |
Posted: Thu Feb 02, 2006 5:38 pm Post subject: |
your questions are way to vague. it depends on the cam, the boost level, the motor, the ammount of money you plan to spend, if it is a race car, if emmsions are an issue or not, etc, etc, etc.
If you just wanted to get a discusion about forced induction, then great, but dude, ask more specific questions if you are trying to get information.
IMHO, I would run aftermarket FI, although a blowthru carb would be a fun project in its own right. |
Posted: Thu Feb 02, 2006 6:38 pm Post subject: |
| Dewey316 wrote: | your questions are way to vague.
Thank YOU!!!!! |
rice B-4 Member
Posted: Thu Feb 02, 2006 7:46 pm Post subject: |
Running ten to twelve punds of boost on a 406 with a cam around 255/262 .575 114 lsa. max opperating range 7200 rpms. Non-emmissions to run on both street and strip. _________________ "Horse power is how fast you hit the wall, Torque is how far you take the wall with you."
99 Camaro Z28 LS1 |
Posted: Thu Feb 02, 2006 8:01 pm Post subject: |
None of us have that much money, we dont' exactly have much experiance with that much.
Really, if you where going to build a setup like that, you would probably be running aftermarket computer stuff, something like DFI. YOu would idealy want a computer that can do fuel trim per cyl, so some sort of SFI support would be wanted. |
Posted: Thu Feb 02, 2006 9:05 pm Post subject: |
hehe well at least the lad answered the question about budget.
is this something you are building or are you bench racing someone or what? ohhh i bet you got to hang around with all these sexy thirdgens last weekend and now you have to have one. can't blame you for that
Posted: Thu Feb 02, 2006 9:40 pm Post subject: |
| wait... who is riceb4? was he at dyno with us or somthing? |
Posted: Thu Feb 02, 2006 10:08 pm Post subject: |
That is Justin.
Posted: Thu Feb 02, 2006 10:39 pm Post subject: |
| Xophertony wrote: | | wait... who is riceb4? was he at dyno with us or somthing? |
The only dude in the crew with an ls1.
So far.
About the fuel supply, look at any fourthgen board and i'm sure you'll find better answers than any thirdgen board. Tons of those guys need to supply their engines with a lot more power than we do. Not that my 247 ft/lbs is anything to scoff at.... The supply setups will probably be very similar to what you'd need to run. Racetronix has a few interesting setups I think including a dual intank pump setup meant for up to ~1000hp. |
